Hi-Flow Throttle Body Problem
Old May 4, 2001 | 06:09 AM
andrewewing's Avatar
I just installed the Proflow high flow throttle body. The install went smoothly and after a few miles to let the computer adjust it runs and idles fine BUT the check engine light stays on. Tried resetting the ECM by pulling fuse but no help. Talked to Jim at Proflow and he is puzzled. His only thought was to check o-ring on MAP sensor which I did. Anybody have any ideas?
Old May 4, 2001 | 08:14 AM
cmnsnse's Avatar
Was your TPS voltage correct?!
I have had NO problems with mine for 10,000 miles
Old May 4, 2001 | 08:30 AM
Prolene's Avatar
Have you reset the ecu before succesfully; just trying to determine if correct fuse removed. All hoses replaced correctly? Hope it gets worked out.
Old May 4, 2001 | 08:45 AM
cmnsnse, I followed the installation instuctions and set resistance on the TPS to the same value as it was on my throttle body. Can you explain about the voltage. Is this covered in the Helm Manual? Prolene, yes I know I removed the proper fuse.
Thanks for all your best wishes and help.
Old May 4, 2001 | 03:10 PM
Roceye's Avatar
Hey,
If the tps voltage is within spec and you can't find any other causes then you are going to have to pull the trouble code to see what's wrong with it. Probably means a visit to the dealer.
does the car still run ok?
Old May 7, 2001 | 02:06 AM
cmnsnse's Avatar
My voltage was slightly off at Idle but dead on at WOT so I left it like that, had the ol' Idle blurbs but then it was fine and never got a check engine light. Maybe you got a bad MAP sensor?
Hasan Shaikh
Jan 21, 2016 08:28 PM
josh7owens
Aug 8, 2012 03:39 AM
my2ks2k
Jul 30, 2008 06:33 AM
JimmyB
Jun 1, 2007 09:12 PM
slater98
Feb 10, 2004 10:26 AM
