HID headlight alignment
Old Aug 2, 2001 | 06:35 PM
Bernie's Avatar
Default HID headlight alignment
The HID headlights on my car are not properly aligned and I don't seem to be having much luck in getting Honda to do this. Any suggestions?
Old Aug 2, 2001 | 06:42 PM
Schatten's Avatar
are you sure you aren't referring to the symptoms as described in this faq ?
the HID's are not adjustable btw.
Old Aug 2, 2001 | 06:47 PM
Speedy's Avatar
If your headlights have a notched pattern, there is nothing to worry about, they are designed that way. If you're in a country where you drive on the right hand side of the road, your right side notch will be higher than your left ( to prevent blinding of oncoming traffic), and vise versa.
i'll be damned (i was just gonna call the dealer about this)....guess i won't bother.
Old Aug 2, 2001 | 07:40 PM
socal28's Avatar
The HID pattern is not adjustable, but the level is.
You need a philips screwdriver and find the hole that leads to the back of the housing. For the drivers side, you need to move the radiator overflow container (it just pulls out, lift up).
You'll see a little slot where stick the philips screwdriver in and twist.
Old Aug 2, 2001 | 07:59 PM
Bernie's Avatar
[QUOTE]Originally posted by Speedy
[B]If your headlights have a notched pattern, there is nothing to worry about, they are designed that way. If you're in a country where you drive on the right hand side of the road, your right side notch will be higher than your left ( to prevent blinding of oncoming traffic), and vise versa.
Skatecboy45
May 24, 2013 06:29 PM
Fizoust
Jan 12, 2010 09:54 AM
J_STATUS
Apr 14, 2008 07:21 AM
HandofBoB
Dec 1, 2006 09:58 AM
hondaboy82
13
Jul 16, 2005 07:35 PM
