High Octane or Plus?
Originally Posted by boofer,Sep 19 2007, 06:32 AM
if 87 octane is $2.69, 89 is $2.79, and 91 or 93 is $2.93 or something, then you're saving like $0.14 per gallon, * ~12 gallon fill up = $1.68 you saved. relative to the $30k you shelled out (or will shell out) for your car, that's nothing. i'll just guess that you fill up 4 times a month, which is 48 times a year, which means you're saving a whopping $80 a year by using lower octane fuel than the manual says to use.
i don't know, but i prefer peace of mind and just filling up with 91/92/93 octane.
Originally Posted by tak_one_77,Sep 19 2007, 09:18 AM
tak_one_77 & YuriArts: Is your octane rating different (US) to others?
Octane Value = (MON + RON) / 2
In Europe and Australia only RON is used.
Octane Value = RON
Since the MON value is usually lower than RON, the Octane Value in the USA is typically 87 Octane (regular), 89 Octane (midgrade) and 91 Octane (premium).
In Europe the equivalent would be 91 RON (normal, though rarely available), 95 RON (eurosuper) and 98 RON (superplus).
Take care,
Siepel
Octane is not majic girlz.
We have a high compression engine. This requires 91 oct. You can use lower octane because the knock sensor retards the timing... up to a point. RTFM and you will see that Honda doesn't advise going to low octane except if you have no other alternative (some f$#$@ places in S. Utah for example).
BUT, higher octane is meaningless because the rate that the fuel burns at is lower than needed, marginally reducing power, but just fine to use.
Lap Dance & McDonalds types: if that is worth messing up your car to you, please sell it.
Most cars that say they require "premium" fuel, do not actually need it. HOWEVER, the S2000 is, in fact, one of the few cars that does need it to keep everything properly maintained. Something lower than 93 Octane would only go in my car over my dead body. 91 is acceptable if its what is available.
The high octane is to prevent retarded combustion in the engine...
so if you go lower the timing will f**k up then you go have to repair your car for thousands of dollar while you save 80 buck a year, and that won't even add up to your damage..
If I ever see anyone pump lower grade to their S2000 out on the street, I'll come by and PUNCH you in the face and tells you to get a different car.
lol
hahhaa
lol
hahhaa
lol
hahhaa
lol
hahhaa
