high rpm
Old Oct 9, 2005 | 06:44 PM
choi's Avatar
Default high rpm
i'm not sure if i'm just paranoid, but it seems when i'm driving (my04) my rpm's a little higher than normal. when i'm going about 60 (in 6th gear), my rpm's at about 4200 and it just kinda sounds loud. just didnt seem to be this loud before at this speed, especially when i'm just cruising, any suggestions?
Old Oct 9, 2005 | 06:51 PM
Silver9k's Avatar
did you buy it used? sound like it has rear gears
Old Oct 9, 2005 | 06:59 PM
choi's Avatar
no i got it brand in dec 2003. can u explain what u mean by i have rear gears, sorry i have no idea what that means.
Old Oct 9, 2005 | 07:44 PM
spa01s2k's Avatar
Wow, 4200 RPM at 60mph (6th gear). Sounds a little bit off to me. I think when I'm at 4200 in 6th gear, I would be going in the 75mph range.
The stock rear, I believe, is a 4.10. Sounds like you have 4.56 or taller, which means your engine has to work at a higher RPM to attain the same speed as a lower gear. The driveshaft spins 4.1 (or 4.56) times to your axles (and tires) 1 time. Thats what he means by "rear gears".
Lower gear = Higher top speed, better gas mileage.
Higher gear = Better acceleration
Old Oct 9, 2005 | 08:59 PM
aronparsons's Avatar
Speedo could be off too.
Old Oct 9, 2005 | 09:42 PM
DrDre1443's Avatar
my 2001 goes 80 MPH at 4200 RPM
for a stock car, you should be about 1000 RPM lower
Old Oct 9, 2005 | 09:43 PM
xviper's Avatar
60 mph in 6th in an '04 would be about 3200 rpm.
To be running 4200 rpm, you'd have to have 5.10 gearing in the final drive. I've never even heard of any S2000s with this gearing, especially in an AP2.
Something is not right.
Old Oct 10, 2005 | 12:08 AM
RACER's Avatar
Old Oct 10, 2005 | 12:09 AM
terahertz's Avatar
major clutch slip?
Old Oct 10, 2005 | 02:05 AM
jakub2000's Avatar
someone swaped your wheels for a set of 12s?
