Hit hard bump going thru construction
Originally Posted by Johnny--2K,Apr 18 2005, 02:48 AM
how fast were you going?
RACER, thank-you, I will crawl under this afternoon and take a look. My thoughts are that, barring direct impact of the diff, subframe, or control arms (of which there is no evidence), I would see rim damage or a blown tire before the suspension would ever break or a subframe weld give away. Could I really have hit with anymore force than some those who track the car over rumble strips at 80 mph? (Mike Garrison, any input??)
All with additional suggestions or experience are appreciated. Thanks.
The only indication that I had before the failure was a slight squeak and a little bit heavier than normal steering. I'm not trying to scare anyone, just saying that the inevitable can happen. I seriously doubt that you incurred any damage to your car although it isn't hard to bend a control arm. If it makes you feel better, get it re-aligned and checked out by a professional.
I would check all your suspension and tire components to be sure. Just last week, I sliced a tire on a hunk of wood in a construction zone. You may have damaged the alignment as well. Take it to a flat, straight area and make sure it still goes well in a straignt line. There's been a ton of construction in my area over the last few years, and I've destroyed my fair share of wheels and tires on them. Fortunately, I've also become very aware of how to check for damages on that kind of stuff.
Jerry_Attric
Aug 20, 2015 12:40 AM
Except in LA.
