Hit rev limiter.... thoughts?
Originally Posted by mxt_77' date='Feb 5 2005, 07:08 AM
Actually, if you hit the rev-limiter your warranty can be voided. The ECU has a counter for each time that the rev limiter is hit. It also has a multiplier based on what gear you're in. E.g., if you're in 4th gear and you hit the rev-limiter, then that counter is incremented 4 times. If you're in 3rd gear and you hit the rev limiter twice, then the counter gets incremented 6 times (3x2). If the counter value is greater than 2, then the dealer will not honor your warranty.
Fortunately, there is a bug in the ECU software. If you hit the rev limiter in Reverse, the counter will actually be decremented. So, if you hit the rev-limiter in 2nd gear, then that means that you need to take the car out (preferably to a big, open parking lot) and stick it in reverse and take her all the way up to 9K RPMs. You'll need to do that twice to get the counter back from 2 to zero. Be careful, because going 35-40mph in Reverse can get tricky.
I take no responsibility for any fool that actually goes out and actually tries this.
Originally Posted by tritium_pie' date='Feb 5 2005, 01:17 PM
that is some of the most beautifully sculpted bullshit I've seen in a while. and while it may be artistic... in the end, it's just b.s.
Originally Posted by Z06-KILLR' date='Feb 5 2005, 08:22 PM
I don't know if I should laugh or cry....for now I'll laugh as I am certain you are joking...right?
Yeah, I'm just screwin' around. If somebody actually plans to try hitting the rev-limiter in reverse, be sure you take your camcorder.
