HKS sitting crooked
Old May 18, 2007 | 05:57 PM
nightcrawler7188's Avatar
Default HKS sitting crooked
i installed my brand new HKS today and it's sitting lower on the passenger side than on the driver's side. i have no clue what the problem could be. i assembled the pipes correctly (the only way they can be assembled) and played around with the hangers but it's still sitting crooked. i tried adjusting the test pipe (the spring bolts make it somewhat mobile) but i still had no luck. did i get an exhaust that was messed up from the factory?
Old May 18, 2007 | 05:59 PM
kamui157's Avatar
Common problem. Loosen the side, have someone hold it in place while you tighten the bolts.
Old May 18, 2007 | 06:01 PM
could you explain a little more? which side do i loosen/retighten? thanks for the quick response
Old May 18, 2007 | 06:19 PM
nearwater4me's Avatar
Wow.. I'd like to know this too, cuz my HKS is coming in next week.
Did you try playing w/ the hangers?
I think you might have to bend the passenger side hanger.
Some people mentioned that slight modification was needed.
Good luck, and keep us updated!
Thanks.
Dan
Old May 18, 2007 | 06:22 PM
i really don't see how i can bend the metal hanger.
kamui157 seems to know but i need some more information on his method.
Old May 18, 2007 | 06:35 PM
kamui157's Avatar
Loosen the bolts next to the rear resonator. Don't have to remove the bolts but enough so you can move the canisters around. Have someone hold it in a position where you want it (Hold tightly) and secure the bolts.
At first, my install was perfect, but I messed around and took off one canister for cleaning. When reinstalling, the one side I took off was hanging higher than the other. Probably due to hanger position. Someone advised me what to do what I just said earlier and everything is level again.
Old May 18, 2007 | 06:39 PM
ohhhhhhhhh i see what you're saying. the bolts don't just go in dead center and that's it. i need to position it then bolt it in the exact position i want it. hmmmm ok thanks!
Old May 18, 2007 | 06:41 PM
so should i unbolt the pipe that the mufflers connect to? or the pipe that connects to the test pipe?
Old May 18, 2007 | 06:43 PM
kamui157's Avatar
See your pictures? The bolts to the left and right of the resonator? Those...
Old May 18, 2007 | 06:45 PM
ahhhhhh ok.
thanks a lot for the help!
oh and does your screen name have anything to do with Gackt?
herecomesboost
Jun 26, 2012 06:32 AM
markfromaurora
Aug 25, 2008 01:51 PM
cmn
Oct 7, 2007 06:36 PM
Profoundanswerzs
Oct 30, 2006 11:48 AM
Projekt
Socal Swap Meet
Apr 27, 2006 01:16 AM
