Honda brake fluid, or others OK?
Old Jan 25, 2006 | 05:57 AM
24s2k7's Avatar
Default Honda brake fluid, or others OK?
I'm bleeding the clutch today. Wondering if I need to go get some Honda brake fluid or if others are ok. Also, I am just going to be getting the air out, not replacing the fluid. So is it ok to mix something like Valvoline with the original Honda fluid?
Old Jan 25, 2006 | 07:10 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
I would not mix.
Drain, flush,and fill it ;Valvoline DOT 4+ is more than enough for any kind of street driving.!!!
Old Jan 25, 2006 | 07:13 AM
ruexp67's Avatar
I wouldn't get DOT4. A quality DOT3 is more than good enough for a clutch. Honda's or any other $1.98 bottle at Autozone.
The Problem with DOT4 is that it is much more Hydroscopic and will absorb more water requiring service more often and is itself more expensive in the first place.
I usually get the Valvoline DOT3 for street car brakes and any clutch fluid changes. I save the ATE Superblue DOT4 for the brakes on the track car.
sleep
Dec 10, 2015 03:28 AM
EF9 Sedan
Mar 31, 2015 04:26 AM
Memo6453
Jul 23, 2014 09:41 AM
ls1->s2k
Feb 2, 2012 03:52 AM
s2krazy01
Jul 2, 2010 08:00 PM
