Mixing DOT 3 and DOT 4Brake Fluid
Old Dec 9, 2015 | 11:25 PM
sleep's Avatar
Default Mixing DOT 3 and DOT 4Brake Fluid
Hey everyone
Im planning to replace the fluid inside the clutch reservoir since it's about time. However, I have no plans to bleed the line, just clean and fill the reservoir. I currently have Motul RBF600 Brake Fluid in the reservoir which is a DOT 4 fluid. Is it okay to extract the DOT 4 fluid inside the reservoir using a turkey baster and replace it with Honda DOT 3 brake fluid? If not, can I just fill the reservoir using Honda DOT 4 brake fluid? Thanks in advance
Old Dec 10, 2015 | 12:25 AM
windhund116's Avatar
I replaced the OEM Honda fluid both brake and clutch reservoir with ATE yellow (Dot 4). No problems. ATE states that their Dot 4 stuff is miscible with Dot 3.
BTW... I used a syringe to draw out the old fluids. Less spillage, compared to a baster.
Old Dec 10, 2015 | 03:21 AM
blueosprey90's Avatar
It is acceptable to mix DOT 3 and DOT 4 brake fluid, but DOT 4 has somewhat higher boiling points.
But depending on how old your brake fluid is, it would make sense to bleed the system since DOT 3 and DOT 4 absorb moisture over time. Billman has a gravity bleed system that works.
https://www.s2ki.com/s2000/topic/995...eding-revised/
Old Dec 10, 2015 | 03:28 AM
Slowcrash_101's Avatar
Dot3 is less prone to moisture absorption, but has a lower boiling point. On a street car you'll never notice the difference. I auto x regularly and use valvoline dot3/4 never had a problem.
NobleAccord
Sep 18, 2016 06:31 AM
RoninS2k
Jul 2, 2012 12:38 PM
skool u
Nov 27, 2009 08:51 AM
myflys2k
May 25, 2009 06:44 PM
samsam5886
Nov 21, 2008 04:23 PM
