Hot coolant smell
Old Feb 28, 2003 | 08:04 PM
ant_knee's Avatar
Default Hot coolant smell
When I got out of my car tonight, I noticed the smell of hot antifreeze/coolant and hot metal. My temperature guage didn't show me to be running hot, and I had not been driving the car hard at all. I am due for an oil change, (which I'm getting tomorrow) but my oil level is full. This is the first time I've noticed it. Anyone else experienced this? Should I not worry about it?
Old Mar 1, 2003 | 06:28 AM
jguerdat's Avatar
The temperature guage isn't a precision instrument - it's designed to show only gross changes so Honda doesn't get "my friend's car runs cooler than mine by 5 degrees" complaints. How were you driving in the last 5 minutes? Getting on the gas a lot is certainly going to increase temps.
I wouldn't worry about it. You could check your overflow tank when you notice the smell to see how much higher than normal it is since higher temps will cause more liquid to be pushed out. I can also point out a recent case of smelling an antifreeze-like smell on my wife's new M-B C230K which turned out to be the factory-fill of windshield washer fluid. I've never seen anything like what they used (foams up nicely). Using different fluid removed the smell. YMMV.
Old Mar 1, 2003 | 06:50 AM
monkeymaker's Avatar
I ususally smell the same thing when I V-TEC in first gear. I wonder if it's not the clutch I smell burning though since I've only noticed the stink in first.
Old Mar 1, 2003 | 02:21 PM
ant_knee's Avatar
I'm quite sure it's the clutch that I smelled. I smell it everytime I get out of the car now. I got my oil changed today, and the guy said the cluth smelled like it was getting hot. He topped off the fluid, and I'm hoping that will help. Last night, when I originally posted this thread, I had been driving the car pretty hard. If the smell persists, should I take the car in?
Old Mar 1, 2003 | 02:27 PM
Uncle Fester's Avatar
So now you were driving the car hard? It's very hard to say what the problem is without actually taking a ride with you. This whole problem could be due to your driving technique. A little clutch smell is going to happen though if you run the car really hard. My perception of a little clutch smell and what you're smelling could be totally different though.
Old Mar 1, 2003 | 02:36 PM
ant_knee's Avatar
I'm not sure why I put that I wasnt driving hard in my first post. I just noticed that after you pointed it out. Really, all I did was launch from a dead start, vtec through 1 and 2 gear, but that was it. I wasn't ragging it for a long period of time, though. I would consider it a little clutch smell, but I didnt smell it before, and now I do everytime I drive, whether I drive hard or not. (Sorry for the contradicting posts.)
Reality33
Feb 28, 2014 08:42 AM
yorkies2k
Nov 15, 2013 11:24 PM
trAP2
Nov 23, 2011 09:28 PM
s2kcolin
Mar 22, 2011 02:59 PM
Steven2k
Jan 7, 2008 10:55 AM
