how do gears spin faster?
Old Nov 18, 2005 | 11:53 AM
i_heart_my_DB8's Avatar
Well, the 4.56 gears and the 4.77 gears are different from stock in SOME way, right?
Maybe someone has a photo of the parts right next to the stock components so you can see exactly what's different about them.
Old Nov 18, 2005 | 11:56 AM
44Runner's Avatar
the diameter of the ring gear does not change, it is the diameter of the pinion that does. The ring gear gets "thicker" as the gears get numerically higher to stay in contact with the smaller pinion...
Old Nov 18, 2005 | 11:59 AM
dyhppy's Avatar
now, that would explain it. just by eyeballing it, i didn't see the difference. couldn't we just accomplish the same thing by changing only the pinion and keeping the 4.1 stock ring?
Old Nov 18, 2005 | 01:33 PM
j_t_heilbrun's Avatar
Think of it this way:
The speed your pinion is turning is not changed by doing a gear set.
So for example (and these are just for example not actual tooth counts and are an exageration)
If stock gears have
6 teeth on the pinion and 60 teeth on the ring
so it take 10 rotations of the pinion to turn the ring 1 time
Now you put different gears in and now the
pinion still has 6 teeth and the ring gear has 36 teeth
so now it only takes the pinion turning 6 times to make the ring turn 1 time.
So with the new gears the engine only had to turn the pinion 6 times instead of 10 times to do the same amount of work
Also this is the reason you need to recalibrate your speedo. Since the tranny thinks it's turning the pinion 10 times per revolution and its really only turning it 6 times.
And thats just the beginning after that the outer diameter of your tire comes into play.
Old Nov 18, 2005 | 01:47 PM
dyhppy's Avatar
if both diameters are the same, it shouldn't matter how many teeth each has to do the same amount of spinning. yes, you are correct but that doesn't explin what makes it spin faster/easier. i'm confused and if anyone isn't please help.
Old Nov 18, 2005 | 03:54 PM
The diameters have nothing to do with it is in the teeth. The gear contact isn't on the outside of the gear it is across the face of the ring gear so the teeth are what matter since for that gear to turn the teeth have to drive it. If you made the ring gear and inch larger in diamter and the exact same tooth configuration your wouldn't change your ratio at all.
So with that said, using my previous figures
Lets say at the same rpm in the same gear the driveshaft turns 50 times. And lets say every time the wheels turn 1 time the ring gear turns 1 time. And every time the wheel turns you move 5 feet.
So with the stock gears with the driveshaft spinning 50 times, it causes the pinion to spin 50 times which turns the ring gear 5 times and the wheels 5 times. So you traveled 25 feet
Now with aftermarket gears the driveshaft spins 50 times, it causes the pinion to spin 50 times which turns the ring gear to turn 8.3 times and then wheels 8.3 times. Which propels the car 41.50 feet.
Lets assume these distances happened in the same amount of time. So the gears get the car up to a faster speed since to travel a longer distance in the same time you have to be moving faster.
I hope this makes sense and once again all my figures are completly made up and do not represent true speeds or ratios of the actual car for the simplicity of the explanation
I guess the best way to sum it up is gears make the same input equal more output.
Old Nov 18, 2005 | 04:00 PM
dyhppy's Avatar
thanks for the example. the only part i don't get is that i thought the 4.56 gears make the driveshaft spin more while the wheels move less. no more hp is created, it just spins the engine to the higher rpms faster, giving you the higher power earlier. i still don't get why the engine can spin/rev faster.
oh wait, i think i answered my own question. if the wheels don't have to turn as much per driveshaft cycle, then it puts less load on the engine, allowing it to spin faster but travelling less distance.
is this correct?
Old Nov 18, 2005 | 07:52 PM
the idea of the gears is to get the same amount of power to do more work. More work meaning push the car further with the same power.
TommieB
Mar 5, 2007 04:49 PM
REVZ TO9
Nov 1, 2006 06:48 PM
W0Pdego
Jul 8, 2006 04:55 PM
SSMugen
Jun 3, 2003 02:32 AM
krazik
Jan 21, 2001 09:52 PM
