Final Gears
Old Feb 21, 2007 | 05:24 AM
TommieB's Avatar
Default Final Gears
Are there qualitydiff on them?
Some are up over 1k$ and some are around 500$.
Are most of them miata once or?
Seen that inlinepro uses 300zx ( or was that only diffhouse? ) but otherwise i cant tell the differences on them.
Now for the experts
Old Feb 21, 2007 | 06:31 AM
paulzale's Avatar
read elsewhere that kia's and miata's use the same gears and they can be had for around $300.
https://www.s2ki.com/forums/index.php?showt...0&#entry3220150
http://forums.s2ki.com/forums/index.php?showtopic=182171
Now, I would like to know more as well. These are from 2004
Old Feb 21, 2007 | 07:12 AM
freq's Avatar
https://www.s2ki.com/forums/index.ph...ic=182172&st=0
7 pages worth of reading.
Old Feb 21, 2007 | 09:53 AM
Swiftoy's Avatar
I just picked up the mazda gears 4.44 and am having them cryo treated I should be getting them back by the first part of next week and then to have them installed. I pulled the diff myself it is very easy you can save a bunch of money if you can do it yourself. You can get the 4.44 from racing beat for 450.00.
Swiftoy
Old Feb 21, 2007 | 11:17 AM
paulzale's Avatar
I am looking into the Kia gears (4.77) from a salvage yard less than $100! I just need to see if 4 x 4 are the same as 2wd on the sportages.
Old Feb 21, 2007 | 01:41 PM
Swiftoy's Avatar
Buyer beware go the cheap route and get big expensive fix when go boom! Not wise to put in used gears. To each there own.
Swiftoy
Old Feb 21, 2007 | 02:09 PM
JLEEzAP2's Avatar
there is a groupbuy for .77's still i think anyway...
Old Feb 21, 2007 | 07:33 PM
Sr2oD3's Avatar
excellent post! Thanks for clearing up so many questions!
Old Feb 21, 2007 | 07:53 PM
stealthx32's Avatar
Originally Posted by Hardtopguy,Feb 21 2007, 10:57 PM
Do my 4.56's make noise? YES they will make a very faint whine around 3500-4000 rpm. Most people won't be able to hear it over the exhuast or radio.
Er? Can you explain how rpms have anything to do with anything?
Old Feb 22, 2007 | 02:13 PM
Steven2k's Avatar
according to some of the members, the much needed yellow box does not work with the 06. is this true?
