How do I remove the steerig wheel cover?
Old Oct 6, 2003 | 12:59 PM
Road Rash's Avatar
Default How do I remove the steerig wheel cover?
I see no screws holding the steering wheel horn/button cover. Does it just pull off?
I'm afraid to pull on it with the airbag and all.
Anyone ever done it?
Old Oct 6, 2003 | 01:47 PM
3ngin33r1's Avatar
1. Disconnect the negative battery cable, and wait at least three minutes before beginning work.
2. Remove the access panel from the steering wheel, then disconnect the connector between the cable reel 2P connector and driver
Old Oct 6, 2003 | 02:03 PM
Road Rash's Avatar
Thanks 3ngin33r1, I didnt want an air bag blowing up in my face while trying to get the cover off.
Old Oct 6, 2003 | 02:25 PM
3ngin33r1's Avatar
Anytime. If you need anything else just let me know.
Old Oct 6, 2003 | 05:43 PM
Road Rash's Avatar
Well, I just got home and tried it, I got the reel connecters and horn lead off, but when I pull on the steering wheel cover it wont budge. I dont want to pull any harder cause I'm afraid I'll break it.
Does it just snap or pop off?
BTW, I need this off because the block head who owned the car before me put his own custom badge on the wheel cover and I need to get all the exess glue off before I throw my Rick's "S" badge on.
Old Oct 6, 2003 | 05:47 PM
3ngin33r1's Avatar
Did you loosen the two Torx bolts?
Old Oct 6, 2003 | 06:01 PM
Road Rash's Avatar
Ok, I understand now, The airbag and the rubber cover are 1 piece right? I thought the cover was a seperate skin that could be removed w/o the airbag.
Guess I'll have to scrape the glue off with it on the wheel.
Old Oct 6, 2003 | 08:08 PM
3ngin33r1's Avatar
Most likely since the cover would de designed to either split or blow out to the side if the airbag went off.
What glue?
Old Dec 12, 2007 | 01:33 AM
GiorgoS2k's Avatar
may i ask something?
i want to remove my steering wheel, because i buy a new (oem) in better condition. Will i have any trouble to removing?
thank you
Old Dec 12, 2007 | 07:38 AM
Hockey's Avatar
Autozone has "steering wheel pullers" for rent. All the above process is correct, but may still leave you with a stubborn wheel that won't let go of the hub. Thats where the Autozone tool comes in.
HTH,
Hockey
