How do I turn off the check engine light
Old Oct 22, 2004 | 10:05 AM
ehonda's Avatar
Default How do I turn off the check engine light
Hi All,
I added a K&N intake and now the check engine light came on. I just want to turn it off...is there a fuse I could pull to reset it or something else to make it turn off.
Thanks for any help.
-Jay
Old Oct 22, 2004 | 10:07 AM
hpark's Avatar
Originally Posted by ehonda,Oct 22 2004, 10:05 AM
Hi All,
-Jay
perhaps you should actually check to see nothing is wrong?? CEL != maintenance required light?
Old Oct 22, 2004 | 10:10 AM
ehonda's Avatar
I should clarify not a new intake but just the K&N filter. The rest is the same....can't imagine that the air filter is not installed properly. Other than that everything is stock.
thanks
Old Oct 22, 2004 | 10:18 AM
RACER's Avatar
It's the second fuse from the top in the right column of the interior fuse box. It is called the backup fuse, 7.5 amp. The 1st (top) slot is empty .
Take it out for 30 seconds. Also recheck your work, vacuum lines, etc.
btw, the maintenance required light is different from the check engine light.
Old Oct 22, 2004 | 10:35 AM
ehonda's Avatar
I just checked the car and actually it is the Maintenance Required light that is on.
I didn't realize the car had a both a Maintenance Required light and a Check Engine light.
I read in the manual that things such as not having the gas cap closed with three turns or more etc. can make this light come on. All I have done is take off the old air filter and replace it with just a K&N filter element all hoses etc. are the same.
So to clarify I am looking for how to turn off the Maintenance Required light.
Thank you very much for all the help thus far,
-Jay
Old Oct 22, 2004 | 10:48 AM
RACER's Avatar
Yes, something as simple as a loose fuel cap can throw a cel. To turn off the maintenance required light, with the ignition off, press down on the trip meter and hold down while turning ignition on. Continue to hold down trip meter until maintenance required light goes out, about 2-3 seconds.
Old Oct 22, 2004 | 11:05 AM
ehonda's Avatar
Thanks a lot! That did the trick.
I appreciate the help,
-Jay
Old Oct 22, 2004 | 04:48 PM
RACER's Avatar
no problemo
socal28
Apr 5, 2018 09:43 PM
Evo9toAP2
Mar 15, 2010 10:31 AM
Psicho54
Jan 24, 2007 09:40 AM
scottl55
Sep 15, 2004 07:10 PM
S2quick4U
Jul 1, 2003 03:28 PM
