HOW DO YOU SHUT OFF MAINT REQUIRE LIGHT ON S2000
Old Mar 9, 2006 | 09:48 AM
jang's Avatar
Unhappy HOW DO YOU SHUT OFF MAINT REQUIRE LIGHT ON S2000
I just bought a used 2002 S2000 and did my first oil change but I can't shut off maint required light. Would you have any suggestions or cure.
Old Mar 9, 2006 | 09:53 AM
dogas's Avatar
USE TEH SERCH
Old Mar 9, 2006 | 10:01 AM
gomarlins3's Avatar
How you reset the 'Maintainance Required' light:
Step #1: Read the manual
Step #2: See step #1.
Old Mar 9, 2006 | 10:15 AM
Enthralled's Avatar
sorry i have an 04 it's a little different i believe
Old Mar 9, 2006 | 10:19 AM
CypherAZ's Avatar
push down the trip button, turn key to stage 2. Wait until it stops flashing, then start the car.
Old Mar 9, 2006 | 10:22 AM
flagstaffhonda's Avatar
Spammer
Here is the quote from the owner's manual in case you don't have one....."To reset the maintenance required indicator, turn the ignition switch to the LOCK position, then press and hold the trip meter reset button while you turn the ignition switch ON. Continue holding the button until the indicator resets (the indicator light goes out)."
Old Mar 9, 2006 | 10:25 AM
freq's Avatar
Keep yelling Jacka$$.
Old Mar 9, 2006 | 12:21 PM
midnightmethane's Avatar
thanks for the help...i had the same problem...the trip reset button thing works!!!
Old Mar 9, 2006 | 03:00 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Had my car for 6 years,and that f%$#ing light kept on flashing,all this time.Thak you guys.!!!
Old Mar 9, 2006 | 03:20 PM
camera obscura's Avatar
I think this was covered once... maybe twice before.
