How to install JDM honda badges?
Old May 4, 2004 | 03:02 PM
TunedS2000's Avatar
Default How to install JDM honda badges?
I could not figure out how to take the stock ones off... Any advice?
Old May 4, 2004 | 03:54 PM
Hokie_S2K's Avatar
Here you go:
http://www.handa-accessories.com/S2000/s2kblkchrm.pdf
I also recommend using 3M adhesive remover to get the old adhesive off (I got the 3M stuff from West Marine).
Old May 4, 2004 | 04:25 PM
ntphan's Avatar
The rear is easy. Just follow the instruction above.
The front is harder to remove. I was not able to remove it in one piece. I used the string as instructed to loosen the emblem. I then slid old credit cards under and around the emblem then pull the emblem up firmly. You will most likely break it. Without the credit cards, you may scratch the bumper.
Old May 4, 2004 | 04:53 PM
energy88's Avatar
On my '04, the front OEM badge popped off a lot easier than the rear.
I had heard rumors on this board of a new front nut design that would have to be cut off, but it took only moderate pulling effort and the securing nuts that were originally present were missing when the badge came loose.
Old May 4, 2004 | 05:31 PM
JTAustin's Avatar
I replaced my 04 badges with JDM. Rear badge was easy with 3M adhesive remover and floss. Front badge....what a pain! 3M with floss will only get you so far. The new locking push on
"washers" needed to be cut off using small wire snips. I had a mirror propped up in the correct viewing angle with a flashlight to see what was going on. Once I got onto the post with the snips it was relatively easy.
My suggestion: get out a mirror and look at the underside of the badge you have on the car. If you have the locking washers, do what I did. I knew nothing about it until I could no longer feel my fingers from trying to pull off the original badge.
I ordered 2 more locking washers from the dealer to secure my JDM after I installed it. Opinions vary on whether you need these or just need the adhesive on the badge. After shelling out $$ for these from Australia, I decided they were not going to be ripped off. I put a piece of tape around my index finger and stuck the washer to it, then felt for the post and pushed it on. Easy.
Good Luck!
JT
Old May 4, 2004 | 05:42 PM
TunedS2000's Avatar
so there is no way to save the washers? Where you JDM a little smaller then the stock ones? Mine are...
Old May 4, 2004 | 06:25 PM
JTAustin's Avatar
I could not save the washers. I paid about $2 and waited 3 days for them from the parts dept.
I got my badges from Muz. They seemed to be close to the same size.
One more thing...I had to push the rear badge from the plastic posts (different fastner) behind the sheet metal to get it to come off. Pretty simple to do. It wouldn't exactly fall off with just 3M and floss!
Have fun...and don't get frustrated with the locking press washer if you have them (most likely).....patience. Little snips = your best friend!
Old May 4, 2004 | 10:50 PM
SARmedic's Avatar
Pardon my ignorance but what do the JDM badges look like?
Old May 5, 2004 | 03:07 AM
JTAustin's Avatar
solid color coded badge.....like bmw badge.
Old May 5, 2004 | 04:01 AM
TunedS2000's Avatar
I think they look way better. Gives the car a different look. Mine are the Red ones.
Speedracer
Aug 15, 2004 08:31 AM
1qwks2k
Aug 25, 2003 06:57 PM
revnitup4u
Jul 23, 2003 12:36 PM
