How to make a stronger diff.
Old Apr 8, 2003 | 04:54 PM
BrandonS's Avatar
Default How to make a stronger diff.
If i were to buy gears from ricks, say the 4.77's, how can i go about making the differential stronger. I don't drag alot, but would like to enjoy a race every now and then. What besides cryo treatment could i do to re-enforce my rear differential. Thnx,
Brandon
Old Apr 8, 2003 | 05:14 PM
AusS2000's Avatar
Don't Comptech make reinforced end caps for the diff assembly?
Many of the diff failures have been broken end caps resulting in internal carnage.
Old Apr 8, 2003 | 05:15 PM
S2000 Driver's Avatar
Yes, they do.
Reinforced Differential Housing (S2000)
$469.95
Developed to help retain the differential
and ring gear from getting shoved out the
back cover. Housing is sold on exchange basis.
Core charge is $370 and will be added to your order.
If you've already broken yours, this core charge will
not be refundable. Photo shows it with the
ring & pinion and differential already put back in.
They are NOT included in this kit.
Here's the link:
http://solar.innercite.com/comptech/550040.html
Old Apr 8, 2003 | 07:49 PM
Wesmaster's Avatar
Other than the Comptech bearing caps and cryogenic treatment there's nothing I'm aware of that you can do. If we could get someone to make a stronger housing, out of a stronger metal, that would be an option.
Old Apr 8, 2003 | 10:42 PM
SanchothePanda's Avatar
I wouldn't think you'd need a stronger diff. for different gears. There's no increase in power, just a change in how much gets transferred to the wheels.
Old Apr 8, 2003 | 11:12 PM
BrandonS's Avatar
I'm not worried about the increase over the previous gears..., i'm worried the S has a weak rear end as is. Just attempting to build a tough car i can have fun with as i please.
Brandon
Old Apr 8, 2003 | 11:56 PM
Fastlane's Avatar
[QUOTE]Originally posted by SanchothePanda
[B]I wouldn't think you'd need a stronger diff. for different gears.
Old Apr 9, 2003 | 12:22 AM
VTEC Racer's Avatar
Originally posted by Fastlane
I think you still do , I just broke my final gear (J's 4.44) after putting 15Kmiles on them . I have never tracked the car or even done drop clutch launches !
Ouch. Sorry to hear that. What type of clutch do you have? Do you know what the cause of the failure was? After seeing the gears, how was the contact pattern? Thanks.
Old Apr 9, 2003 | 12:51 AM
VTEC Racer's Avatar
Old Apr 9, 2003 | 07:01 AM
AusS2000's Avatar
If you do have the diff reinforced make sure whoever does it knows what they are doing. If I remember correctly you have to set a certain amount of backlash. If it is not set to spec it will destroy itself.
