how much hp i'd be getting with this setup?
Old Aug 16, 2004 | 04:18 PM
s2kboy03's Avatar
Default how much hp i'd be getting with this setup?
k so far spoon style CF airduct/spoon filter/T1R exhaust with testpipe and professionally and properly tuned apex vafc...what would be the estimate hp numbers be to the wheels and the crank? my goal wanting to reach 240 whp...also got a silvers epower voltage stabilizer that claims to gain 2-3 whp but i highly doubt it...and if combined with a grounding kit suppose to claim gains up to 7 whp...u think t1r earthing system combined with the stabilzer would offer good gains?
Old Aug 16, 2004 | 05:23 PM
Silver9k's Avatar
I doubt the earthing and stabilizer add any power...especially on a coil-over plug set-up.
My guess, with all that, you could be at 215-220whp. That, people have shown 207whp with only having the VAFC...and the test pipe is good for some power too...then the other with the other two...ya right in that range sounds right.
I also have a high NA whp goal with my car...265 has been done...but that requires a lot of work.
if you want to get to 240, your going to need a header (doesn't help peak too much but is good for mids), probably head work...
another thing that will help is a lightweight flywheel, and lightweight driveshaft...they won't add hp, but they will free some up thats already there (reduce drivetrain % loss).
Old Aug 16, 2004 | 05:26 PM
Fongu's Avatar
I can tell you a number (say +5 to +15 whp peak), but it would be useless. You can find a dyno plot somewhere of another '02-'03 car with the exact same mods and same VAFC settings, but that would just be an estimate, since every car and components have tolerances not to mention any temp. and humidity differences during the dyno run. Anyways, if it was professionally tuned why wasn't it done on a dyno? How do you know they did anything good? What were the final A/F ratios, is the engine running unsafely lean? How do you know?
As far as reaching 240 whp NA (assuming that is +40 whp measured on a Dynojet), it not going to happen with bolt ons. Think engine rebuild, stroked, bored, increased compression, ported head, aggressive cams, and real stand alone engine management. Then maybe you'll get there, it might even be streetable. Lose the AC, lightweight flywheel and light and small wheels might put you over the top.
With the big cost of parts and labour to get to your goal, some dyno time is going to be relatively cheap. If you just care about bragging numbers, make one up. If you care about real performance, prove it for yourself with testing on your car. BTW, voltage stablizer and earthing kit, junk. Hey prove me wrong with a dyno.
Old Aug 16, 2004 | 06:00 PM
s2kboy03's Avatar
thx for the tips guys...i appreciate the help
Old Aug 16, 2004 | 06:59 PM
Ludedude's Avatar
Administrator
Please don't start more than one thread on the same subject in multiple forums.
christopherboon
Jun 3, 2008 07:39 PM
batikan
Apr 19, 2006 07:11 AM
chicagos2k
Sep 29, 2005 12:02 AM
s2kboy03
Sep 23, 2004 02:43 PM
s2kboy03
Aug 17, 2004 09:36 AM
