How much slower with a passenger?
Old Jan 11, 2002 | 03:06 AM
Nachtmeister's Avatar
Originally posted by Takashi KazuMori
It always depends how heavy your passenger and you add up to be ...
Fat Boys, Fat Boys - Watcha gonna do, watcha gonna do when they come for you
Old Jan 11, 2002 | 03:19 AM
FCGuy's Avatar
F=ma (force = mass * acceleration)
Say the curb weight is 2800 lbs or so with fuel. Add 150 lb driver. Add 150 lb passenger. Passenger adds about 5% weight to vehicle. Accel slows down 5%. All other effects are secondary/tertiary...
Top speed will barely move. Top speed is almost totally determined by hp and air drag. Adding weight impacts the rolling friction, but it is just a minor component at 150 or so mph.
More hearsay-ish: Handling might slightly improve due to better lateral balance. Plenty of autox'rs have commented on how they had better runs with a passenger. Maybe having someone there makes them perform at their best, maybe it is the balance.
I believe the S2000 load is indeed 400 lbs. Most 2-seat roadsters have small loads like this, though this is about the lowest. I personally wouldn't worry about exceeding it by some.
Old Jan 11, 2002 | 03:29 AM
2kturkey's Avatar
FC, I think you're just about spot on. My experience with a G-Tech and on the track shows very similar results.
Old Jan 11, 2002 | 04:34 AM
moonpie's Avatar
I have a co-worker who weights 270lbs. I weight 180lbs, so together 450lbs. I was taking him to lunch the other day and I went WOT on the interstate and did not get the response I was used to. What am I suppossed to say to him when he wants to ride in my car? "Hey buddy, you gotta lose about 100lbs if you wanna ride in my car you fat bastard!"
Hopefully I didn't compress my springs too much
Old Jan 11, 2002 | 05:18 AM
Sideways's Avatar
My manual says 440 lb limit. When running the front straight at the Streets of Willow, I would hit 101 with a passenger and 104-105 without.
Old Jan 11, 2002 | 05:34 AM
VisualEchos's Avatar
[QUOTE]Originally posted by Spanky
[B]If a stock s2000 is capable of low- 14s, high-13s,
Old Jan 11, 2002 | 06:19 AM
Chapstick's Avatar
I have spent the last 5 years drag racing. This is pretty standard use on that side of the fence. For every 100 pounds you can remove from your car (everything else equal) you will drop .10 second from your ET. So every 100 pounds gained would slow you down .10 second in the 1/4 mile.
Hope this helps.
Old Jan 11, 2002 | 07:28 AM
WPS's Avatar
WPS
is that really true about the 440lb maximum?!
Old Jan 11, 2002 | 08:33 AM
[QUOTE]Originally posted by Chapstick
[B]I have spent the last 5 years drag racing.
Old Jan 11, 2002 | 09:11 AM
bguernsey's Avatar
I think (not certain) that the max load is printed inside the door on each car and I remember it being 400lbs on the 2000 S2000. I don't remember seeing 440lbs, so I wonder if this has changed?
Byron
