how to put on voodoo shift knob?
Old Oct 24, 2005 | 02:33 PM
boyguan's Avatar
Default how to put on voodoo shift knob?
i just got one with the 6spd pattern engraved ontop.
when i screw it down the pattern is upside down
how can i get it to be facing correctly?
Old Oct 24, 2005 | 02:36 PM
SIIK2NR's Avatar
You can add tape to the threads on the shifter.
Old Oct 24, 2005 | 02:48 PM
WVtwisties's Avatar
flip your gear box!
Old Oct 24, 2005 | 02:50 PM
dozen5's Avatar
or blue loctite.
Old Oct 24, 2005 | 02:51 PM
centralcoastbuc's Avatar
I wrapped the threads with teflon tape pretty thick before installation. It has been tight ever since.
frank b's Avatar
Get BLUE Locktite. Use a few drops on the threads and get the knob down as far as possible and then back it off until the pattern is where you want it. Let it dry for a few hours and you're good. The blue stuff is what you need because if you need to remove the knob, you can get it off with a sharp twist. HTH.
Old Oct 24, 2005 | 04:34 PM
boyguan's Avatar
i do not think the teflon tape will do much in the sense of holding it down. and i think i would have to put so much to make it tight that the threads would not even seat well.
i think the loctite will work. i am just relying on the adheasiveness of the loctite for this method. anyone have any other suggestions?
Old Oct 24, 2005 | 04:35 PM
aznprydefloz's Avatar
Originally Posted by WVtwisties,Oct 24 2005, 02:48 PM
flip your gear box!
Old Oct 24, 2005 | 04:55 PM
eepr5's Avatar
whatever you do, DO NOT get RED loctite unless you really really like the knob and NEVER want to remove it
Old Oct 24, 2005 | 05:42 PM
Harpoon's Avatar
It would be pure luck if the Teflon tape happened to allow you to align the pattern. My guess is you're reading the useless instructions that come with the knob and I know that blue glue isn't one of the options. Don't worry about the instructions - the guys at Rick's don't follow them anyway - go with the blue glue.
