How to remove the parking light bulbs?
Old Jan 5, 2003 | 03:29 PM
bertsirkin's Avatar
Default How to remove the parking light bulbs?
I want to change the bulbs in my parking lights, but can't get my (apparently too fat) hand into the cavity under the hood to get the bulb socket. I can't imagine that I'd have to remove the bumper and headlight just to change the bulb.
Is there a trick to this?
Old Jan 5, 2003 | 03:53 PM
darkknight1999's Avatar
The hole is very small. You can try removing the inner wheel liner (this should work), or just grab a friend with a small hand and have him change it for you. If you lived closer I'd do it for you, or you can drive up to Mass and I'll do it.
my .02
Old Jan 5, 2003 | 04:09 PM
bertsirkin's Avatar
my .02
Well, if you say it can be done, I'll risk losing a finger or two first and try to change it myself! Somehow when I first tried it, I just figured there had to be a trick to it!
Old Jan 5, 2003 | 04:18 PM
Nope sorry.. no trick that I know of. I will suggest getting a mechanic's mirror and a really small light so you can see where you need to reach. You will most likely have to pull back the inner wheel well lining to do it.
Just turn the wheel so that the front of the wheel is turned in facing the engine bay. After that remove the cilps in the front of the cover and change the bulb.
Hope this helps!
racer_X_123
Jun 19, 2011 04:07 PM
MR J
Jul 25, 2010 01:02 PM
s2000tim
Jun 18, 2007 10:39 AM
s4play
Feb 23, 2007 01:47 PM
Tyraid2K
Apr 21, 2005 06:21 PM
