How To SideStep the S2000 Clutch
Originally Posted by PanteraKitty,Oct 16 2006, 09:27 AM
Is there any damage that comes from bogging the motor? I know you wont get an optimum launch, but is there any damage?
As for sidestepping, if you are hitting the foot rest, then go up a little first, then off to the left while continuing up. You should be able to start moving your foot sideways before the engagement point anyways. If you can't, seriously get quicker feet. Go running, loose some weight and add some functional muscle to those legs. It would be healthy anyway.
Originally Posted by Emil St-Hilaire,Oct 16 2006, 11:31 AM
ca torche en masse,mon ti-pit.!!!
Originally Posted by PanteraKitty,Oct 16 2006, 12:27 PM
RED MX5, you said, "Bogging the motor is also not a good idea, so make sure the tires break lose cleanly."
The issue is something called "stiction." If you are not familiar with the term you can learn what it means here.
It takes a lot (A LOT) more force to break the tires loose than it does to keep them spinniing, and a short, sharp, shock, does it quickly and with the least amount of total force. When you bog a launch you have failed to break the stiction of the tires, and the loads on the driveline skyrocket.
This is one of the many ways one can trash a car trying to do this kind of thing.
Even launching when the car is on an incline increases risk to the driveline. When the front of the car is higher than the back there is additional weight transferred to the rear tires, and they'll deliver more traction (and have higher stiction) as a result. Add a load of groceries in the trunk and a full tank of gas, and a car that normally breaks the tires loose easily when the clutch is dropped at 6k can end up bogging and not overcoming the stiction, and you may end up picking parts of the car up off the ground.
I mention Spridgets (AH Sprites and MG Midgets, AKA "bug-eyes") in many of my posts, because the little cars are so much fun. Even though they have less power than some small tractors they'll still light the tires and chirp them on the 1-2 shift, because the flywheel is heavy and a good driver can use the flywheels inertia to overcome the tires stiction. Done in a reasonable way this won't hurt the little cars, but if you install racing rubber or blow a couple launches the driveline will be hosed. You can even rip the rear end out of a Chevy if you blow a launch (though it's a lot harder if the car has the HD 12-bolt differential).
Anyway, a bog is what happens when stiction wins and the driveline loses. Stiction can also result in excessive clutch slip and overheating and/or glazing of the clutch.
DFul4d
Jul 30, 2003 06:40 AM
