how to test limit?
Old Jun 27, 2005 | 03:30 PM
dyhppy's Avatar
Default how to test limit?
is there a way to safetly test the limits of the car without going to the race track? like when going around a curve, how do u know how fast it can be done safely? is there a feeling or noise in the 04/05 before it's about to slip? obviously experience is king, but any quick lessons?
thnx
Old Jun 27, 2005 | 03:32 PM
i_heart_my_DB8's Avatar
Ha ha ha... dude, you're going post-CRAZY
But I'll answer your question in one word:
NO.
Old Jun 27, 2005 | 03:38 PM
JAXrsx's Avatar
thnx
One way would be to find a large open parking lot or equivalent, and hope that the copss don't mess with you.
The best way is to try out Auto Cross. Its MUCH safer than a closed track, and typically very affordable.
Craig
Old Jun 27, 2005 | 03:42 PM
FO2K's Avatar
Since you live in SoCal, you have a great opportunity to get to a track for a driving school. If for some reason that doesn't appeal to you, go to an autocross. People there are friendly and will be more than happy to help a novice.
It sounds like this might be your first RWD car. If so, it is even more important to get your car on a track or some event where there are experienced people to assist you.
Old Jun 27, 2005 | 03:46 PM
dyhppy's Avatar
thank you. just boring and curious.
Old Jun 27, 2005 | 03:56 PM
Don't be so harsh on yourself... I think you meant "just BORED and curious"
Old Jun 27, 2005 | 04:49 PM
mikegarrison's Avatar
The best place to do this is not really a race track or an auto-x course. The best place is a skid pad.
As someone mentioned, a large open parking lot can make a fine skid pad. But you should get permission, or you may get in trouble.
Don't just go in random circles. Use a chalked-out circle to give you a good reference.
Old Jun 27, 2005 | 05:17 PM
Indecision's Avatar
Make sure your skidpad/g-circle is large enough to give you lots of room for run off.
Old Jun 27, 2005 | 05:20 PM
Vanos954's Avatar
skid pad doesn't really show you the limits of a car though..just how fast you can go in a set diameter circle...doesn't show the transition capability etc. I know a lot of cars don't pull good skidpad numbers at all but handle amazingly well. Hit up an auto-x if you are looking to do it cheap and see the handling characteristics in the 50-60mph range on tight corners/slaloms which would most likely simulate around town and tight canyon roads but not big sweeping canyons.
Old Jun 27, 2005 | 05:45 PM
That's exactly what it does show you. Everything else mentioned here is more about the limits of the driver than the limits of the car.
If you want to include transition, then put out some cones and do a slalom along with the skidpad.
