Humming noise
Old Dec 28, 2005 | 09:00 AM
tim62's Avatar
Default Humming noise
My S is about 21K miles, everytime I raise the RPM to about 3800 RPM, I will hear a humming noise. However, this noise will go away if my RPM either raised up above or lowed down below 3800 RPM. Does anyone have the same issue? May be at the difference RPM?
Tim
Old Dec 28, 2005 | 10:26 AM
SIIK2NR's Avatar
You have to state if you have any mods...
Location of the humming....
Old Dec 28, 2005 | 10:30 AM
CG's Avatar
CG
My rear diff did that at certain speeds. As it got worse the humming got worse. I hope that's not your problem, it could be as simple as tires or intake noise. Really need more info than you gave.
Old Dec 28, 2005 | 01:52 PM
tim62's Avatar
No, mine is totally stock. The humming noise is from the engine compartment. I think it comes from either the bearing or the pully by the belt in front of the engine.
This should be warranty work if any, however, I dont think it will get any worst. I just try to eliminate the dealer to touch my S as much as possible. Therefore, I asked if anyone has the same noise.
Thanks,
Tim
Old Dec 28, 2005 | 10:30 PM
vtec9's Avatar
does it happen when rev to 3800 rpm while in neutral, or when the clutch is disengaged?
Old Dec 28, 2005 | 10:34 PM
tim62's Avatar
It happens when driving. At 6th gear, it's exactly at 70MPH.
Tim
Peeves
Oct 17, 2015 08:46 AM
TopGear
Sep 16, 2011 04:34 PM
Pinchy
25
Feb 11, 2009 02:08 PM
s2kdriver80
Jan 21, 2009 12:04 PM
eshar4ever
Aug 1, 2008 10:53 PM
