I am going in again to correct the 1-2 grind!!
Old May 29, 2001 | 02:13 PM
s2kmtl's Avatar
Default I am going in again to correct the 1-2 grind!!
Went to the dealership today and took a ride with the mechanic (he drove) and he said that the transmission is definately f'ed up again.
My service rep said I shouldn't have any static from Honda Canada like I did last time (the last time I complained, Honda Canada didn't issue the TSB yet and they said it's my fault!! I fought and won).
So it is possible that the 'correction' for the 1-2 grind is not 100% effective.
I am also getting the synchros for gears 4-5 done as well as I get a crunch at high rpm...
Rob
Montreal
2000 red/black
Old May 29, 2001 | 02:27 PM
Phantom's Avatar
Dang it!
I had the fix done but I could have sworn I grinded a couple times in April.
Old May 29, 2001 | 05:38 PM
S2K-MONTREAL's Avatar
I tried last week to convince them (without success) to fix the grind. Now, I need to call Honda Canada.
Old May 29, 2001 | 05:48 PM
nvmys2k's Avatar
Rob, good luck dude...Hearing all the troubles you guys are going thru with this TSB, I'm really glad that my STooK came 2nd grind free.
Old May 29, 2001 | 05:59 PM
s2kmtl's Avatar
s2k-montreal,
Did you get the TSB done? They have no choice but to correct the TSB. What dealership are you using?
Call Derrick 450-449-5050 at Honda Boucherville. He is taking care of me. Great guy.
Rob
Old May 29, 2001 | 06:31 PM
Sev's Avatar
Sev
Defintaley like Rob says, the TSB has to be done without argument. Robs talking about re-doing the TSB a second time.
Old May 29, 2001 | 06:39 PM
Hey Rob what's up man?
Yeah, I got the TSB done at Excel about 4 months ago and recently, after 5000KM, the grinding problem is 100% back. Like I said earlier, I returned to my dealer last week (Honda Terrebonne: I filed a complaint for the crappy service I got at Excel) and I was told by the mechanic who tested the car that he didn't feel the grind after the car was warmed up.
I heard you made a few modifications, some friend of mine saw your car at the autoshow, did you drive your car last winter again? The last time I saw it was last year, at the Julep meet and about 4 months ago on Champlain bridge, you were with your GF.
Thanks for the tip man, I'm gonna call your guy.
Tony aka Johnny_Yutah
Old May 30, 2001 | 09:17 AM
kingkong's Avatar
I got a second gear grind once so far, and I have had my 2001 for two weeks. It has happened only once, should I bring it in?
Old May 30, 2001 | 10:52 AM
moyopoyo's Avatar
Hey, King Kong...
I have a 2001 too, and i grinded at least five times, and i'm sure that it wasn't 'cause i was driving bad, because i let a friend drive it and he was having the same problem...I haven't had the problem for about a week, but that's because i have been shifting really really carefully when going into second gear. If you keep having the problem, let me know, 'cause i'll look into mine too.
Old May 30, 2001 | 10:42 PM
kingkong's Avatar
So far, no more grinds. But then again, I haven't been really racing it that hard. I got pulled over the other day racing a Type R that was redone by SKUNK. I'll let you know if I grind again.
