I need a battery ASAP
Old Jun 24, 2006 | 11:26 AM
jbotstein1's Avatar
Default I need a battery ASAP
My mechanic just called and he is almost done with my turbo installation, but he says the downpipe is too close to the battery. I have searched for a smaller battery, but I think I am just finding replacements for stock that are the same size. I need something significantly smaller. Help me please. I dyno on Tuesday!
Jonathan
Old Jun 24, 2006 | 01:31 PM
gfacter's Avatar
I think Sears has the Optima batteries
Old Jun 24, 2006 | 02:04 PM
jbotstein1's Avatar
They're smaller?
Old Jun 24, 2006 | 02:38 PM
afwfjustin's Avatar
Ask around on the s2katlanta boards. Also, where are you dynoing?
Old Jun 24, 2006 | 02:40 PM
jbotstein1's Avatar
Balanced
Old Jun 24, 2006 | 03:04 PM
negcamber's Avatar
Several of us use the Hawker Oddyssey PC680MJ. It is much smaller (and also weighs about 10lb less). CCA is lower though and may not be good for cold winter days (in FL, mine has been fine).
You can probably find one locally, but you can also order from:
http://www.sunnbattery.com/item.html?UCIDs...00&PRID=1364181
Here are some pics of this size battery installed (the Genisis uses about the same size case)
If the turbo set up is crowding the battery, what about the AC lines? Or the fuse box? I assume the battery heat shield is removed...are you concerned that the heat may cause problems with the fuse box?
Old Jun 24, 2006 | 03:56 PM
jbotstein1's Avatar
They had to bend the AC lines and I think turn the fuse box sideways so it is more flush against the fender side. By doing that, the OEM battery won't fit.
Old Jun 25, 2006 | 12:20 AM
Ray's Avatar
Ray
Look at AGM battery for Miata
I have American Eagle AGM battery for Miata and has CCA of 530. (much higher than stock)
It's smaller too, although only in length.
Old Jun 25, 2006 | 01:22 AM
BlackNightmare's Avatar
oo i want to see pictures of it when its done
Old Jun 25, 2006 | 03:48 AM
jbotstein1's Avatar
I'll be posting plenty!
