I need help with my shifter.
Old Feb 21, 2007 | 05:59 PM
TurboDSMJ's Avatar
Default I need help with my shifter.
I bought my '01 about 5 Month's ago. When I bought it from the Dealership, the shift knob was aligned correctly. I then bought a Voodo shift knob, with the 6 speed engraving from Ricks. When I put it on, the 6 speed engraving is almost exactly upside down. I tried to put my OEM shift knob back on, and that is off as well. Is there anyway to get the knob to line up properly? I don't know what to do about it, but it's kind of annoying to have a $90 shift knob that doesn't even line up properly. It just won't get tight and line up, it's either I tighten the knob and it's crooked, or I leave it loose and risk it falling off on me.
Thanks for any help, I just don't know what's wrong with the thing.
Old Feb 21, 2007 | 06:04 PM
itsmylittlebrothersbike's Avatar
Put a few drops of Loctite BLUE on the threads before you screw the knob on. Screw it all the way down then back it off until the engraving is where you want it. Let it sit for a couple hours to set. Thats it! Do not use Loctite red. If you do, you will need a blowtorch to get your shiftknob off next time! Good luck!
Old Feb 21, 2007 | 06:05 PM
P.S. The stock knob came with a seperate nut that was tightened after the shift pattern was aligned!
Old Feb 21, 2007 | 06:11 PM
TurboDSMJ's Avatar
Hmm. I don't specifically remember the OEM knob having a seperate nut, but that makes complete sense. Although it'd look rather stupid having that nut on there with the Rick's knob. I guess I will buy some Loctite. Although I was afraid I'd never get it off haha.
PS- Does MY01 have a clock by any chance, I didn't see anything about it in the Manual, but I saw someone mention it in another thread.
Old Feb 21, 2007 | 09:22 PM
oogieboogie's Avatar
it should be on the cluster, under the tach above youre milage
Old Feb 21, 2007 | 09:49 PM
gomarlins3's Avatar
That is in the AP2's not the AP1's. I don't think the '00 or '01's have a clock. The '02's have a clock on the OEM headunit, but not the dash.
Old Feb 21, 2007 | 10:16 PM
AlwaysBoosted's Avatar
MY01 has a clock on my OEM head unit.
Ihaveits2k
Tampa
Dec 23, 2013 11:48 AM
zacksbro11
Tampa
18
Feb 10, 2011 01:26 PM
zbrewha863
Aug 26, 2008 01:28 PM
gusrock77
Oct 14, 2005 02:51 PM
lalaspanda
Feb 29, 2004 05:53 AM
