info on major issues with s2k's
Old Jan 26, 2007 | 01:12 PM
  #21
rugsr's Avatar
yea yea thats it, the S02's
will they hook up real nice or need i upgrade. they have about 80% tred
Old Jan 26, 2007 | 01:26 PM
  #22
K-Lo's Avatar
no experience with S02's but seeing they've been broken in, they will offer optimal grip during launch.
Old Jan 26, 2007 | 02:23 PM
  #23
FISH22's Avatar
Originally Posted by redline8k,Jan 25 2007, 08:18 PM
actually hes worked on a good amount of them, He worked on my other buddys turbo ap1 but he drive the hell out of the car. this car had a v-mount system before the Aem driftcar did. I believe Aem talked with him about it. Not sure, I know the driver of the aem car is friends with him.
Im in chicago also, elgin really. thanks for the reply
-nick
hmmm, elgin, cool. well, i'm stationed in virginia, but i'm from edison park, chicago. my wife is from crystal lake.
Old Jan 26, 2007 | 02:55 PM
  #24
negcamber's Avatar
Originally Posted by rugsr,Jan 26 2007, 10:55 AM
You have a link for this...ive never seen this mod
Megan...or Mugen?
Isn't Megan a bad knock off?
Megan...not Mugen. It appears to be a knock off of the J's Racing BSK which sells for twice the Megan. Megan products are not necessarily bad...just produced at a lower cost without adding in R&D mark-up.
https://www.s2ki.com/forums/index.php?showtopic=444819
Old Jan 26, 2007 | 04:24 PM
  #25
redline8k's Avatar
Yea, my wrx isnt really a wrx anymore, It got a full jdm rac 2.0l drivetrain motor,trans, diffs and all the bolt on goodies, I filped the intake manifold. It has a HKS 2540 turbo kit and is just shy of making 400hp and 400lbs/tr @24psi. It ran 11.90s @115 last year making about 50hp less so its a blast to drive, but Im just looking for something else. Ive had my fun and spent lots of $$$. Im no stranger to 6k launched only mine were off launch control
I also stopped by one of the local honda tuning places and talked with them for a while. Im finding more of what everone here is saying. Good car just be carefull of the diff etc...
Now my only consern is fitting into the car. Im 6'4 250 so once Im in, im and confortable but getting in with the topup or hardtop may be a challange!
thanks for the info, keep it comming.
-nick
Old Jan 26, 2007 | 06:07 PM
  #26
Chazmo's Avatar
I hate when I have to jump into these threads...
Please *don't* launch your cars. You guys think you're recommending something safe to other owners, but you're not. This is not something that you should be recommending to people.
Original poster, the S isn't a great drag car in stock form. If you're actually worried about parts breaking because you need/want to launch your car, you shouldn't buy an S2000.
Old Jan 26, 2007 | 10:20 PM
  #27
brimstone's Avatar
6'4" and 250 lbs might be a bit uncomfortable. I really think you should test-drive if you haven't already.
Old Jan 26, 2007 | 11:27 PM
  #28
zbrewha863's Avatar
Yeah it will probably not be a comfortable car for you bro -- I'm 5'10, 180 and sometimes it's uncomfortable for me! But they do make low seat rails (companies like Backyard Speical and J's Racing) that drop the seat a little to make it more comfortable. But yeah, 6'5" 250 is probably going to work
Old Jan 27, 2007 | 09:35 AM
  #29
redline8k's Avatar
I fit in the car just fine with headroom and legroom, but its getting into the car thats the issue. I have to check it out for sure. Ive already looked into the lower seat rails and a removable wheel just to be on the safe side.
I know I have to loose some weight, I getting married soon anyways.
-nick
Old Jan 27, 2007 | 06:09 PM
  #30
RED MX5's Avatar
Originally Posted by Destro,Jan 26 2007, 10:19 AM
Formally, bump steer is a change in toe as a result of bump or droop. This can cause undesirable effects during acceleration/deceleration, or cornering over bumpy surfaces, as mentioned above. Bump steer is caused (or corrected) by the length and location of the steering link (front suspension) or toe link (rear suspension). Also, semi-trailing arms create lots of bump steer.
A couple of other notes:
Bump steer is a characteristic of independent suspensions. Obviously, a solid rear axle will not have bump steer.
Interestingly, some suspensions are designed purposely to have a certain degree of bump steer.
I haven't read the whole thread, so I hope I'm not repeating stuff that has already been discussed.
Vehicles with solid rear axles actually DO have rolll steer (or more accurately, roll understeer) designed into their geometry. Google it if you're doubtful.
Viewing "bump steer" is a gross over simplification, becuase in reality it is just a side effect of roll understeer, which is not necessarily a bad thing. Roll understeer allows the AP1's to turn in more quickly (due to a stronger bias toward over steer) and then transition more toward under steer (actually less over steer) as the car rolls and takes a set. The outside rear tire turns toward the inside of a turn during cornering, due to roll, and this moves the handling bias towars under steer. Roll understeer also increases absolute grip. Downsides include the aformentioned effects when a wheel hits a bump or dip, but like every other part of a cars suspension design it's a tradeoff. The "bump steer" in the early AP1's was not a mistake or a flaw, but rather a well considered design tradeoff.
