Install PDF
Old Mar 6, 2008 | 05:58 AM
GOS2K007's Avatar
Default Install PDF
Does anyone have the pre 04 pdf install instructions? The pdf I have is for an 07 and does not cover how to remove and install the new front strikers.
Old Mar 6, 2008 | 06:44 AM
shamoo's Avatar
Well now that you mention it, can you post the link of the PDF you have for the 2007 install? My hardtop is in transit and I have an 07. Hardtopguy forwaded me install instructions, but I'm not sure what year it's for. You can check his site, it's posted on there.
Old Mar 6, 2008 | 10:53 AM
Alexei's Avatar
Some hardtop install info is availlable at:
http://www.cheaphondaparts.com/shop/instru...ns/aii23531.pdf
http://lazykiwi.googlepages.com/diy
If you have any squeak or rattle issues after your HT is installed, the fix is also well documented here at S2KI.
For squeaks... go to the dealer and buy some Shin Etsu silicone lube, then apply it to all the soft black rubber seals on the outside edges of the hard top/windshield where the HT mates to the windshield, body, and around the windows.
For latch rattles... the dealer can give you some EPT Sealant (kind of like foam weather stripping), it really doesn't take very much to perform the fix below:
Clickie ---> Squeaks and Rattling Latch Fix
I performed the fix, AND tied down the latch hooks on each side of the lowered soft top with plastic cable ties (rubber bands work too); now my hard top is very, very, quiet - even on the bumpiest roads.
Old Mar 6, 2008 | 11:28 AM
JackS's Avatar
You can Use the stock strikers you already have. I think the're the same. They were only different for earlier MOy's
Just install the rear hardware and place the top on the car and your done.
Old Mar 6, 2008 | 03:59 PM
mzk784's Avatar
I have the PDF for AP1 HT installation, PM me your email so I can forward you the file.
Old Mar 6, 2008 | 07:09 PM
BB_S2K's Avatar
Here is the DIY from S2KI, I used it in conjunction with the install instructions and worked out great. There is also a strikers DIY link in the thread.
https://www.s2ki.com/forums/index.php?showtopic=540666
I believe strikers only need to be replaced on MY00 and MY01. IIRC MY02+ have the correct strikers from the factory.
macr88
Drivetrain
Jul 20, 2011 10:24 PM
gawee77
Jul 6, 2008 09:43 AM
XclusiveAutosports
May 30, 2006 05:48 PM
INFMS
Jun 13, 2004 05:05 AM
longshot
Sep 26, 2003 05:43 PM
