Installation help on Amuse front lip spoiler.
Old Jul 8, 2002 | 01:24 PM
wlfsmith's Avatar
Default Installation help on Amuse front lip spoiler.
Just received my Amuse front lip spoiler and wondering if anyone has the instructions to install it on my car. I see it already has 4 pre-drilled holes for the bolts but I need to know how the other parts come into play. Any help would be appreciated.
Thanks,
Will
Old Jul 8, 2002 | 07:09 PM
joe_s2k's Avatar
Let see.
First off. [list=1]
[*]Place the spoiler underneath the front as if you were going to mount it.
[*]Look underneath and match the holes in the Amuse Lip to the existing bolts holding the plastic undertray to your front bumper.
[*]Remove those bolts because you'll be using the ones suplied with the Amuse Lip.
[*]The two Long bolts go on the outside holes(closest to front wheels) and the 2 short bolts go on the inside holes(underneath your radiator).[/list=1]
Here's the trick with the bolts and the cylinder looking spacers.[list=1]
[*]Attach the Amuse Lip to the underside of the front bumper.
[*]Match the long cylinder spacer with the long bolt and place the cylinder spacer on top of the hole of the Amuse lip.
[*]Slide the bolt through the Amuse Lip hole and through the cylinder spacer.
[*]Thread the bolt using the supplied lock nut into the
[*]Now, do the other 3 bolts.
[*]Use the 2 screws and connect the Amuse Lip to the fenderwell.[/list=1]
It's hard to describe without pictures, but I hope this helps.
Old Jul 11, 2002 | 11:27 AM
wlfsmith's Avatar
Hey Joe,
Just got to the reply. Thanks for helping out with the info.
Will
Old Jul 11, 2002 | 11:33 AM
joe_s2k's Avatar
I hope it works out. It does look much more aggressive with the Amuse or the Mingster IDi Front lip.
Let me know if you notice any handling differences after you put it on.
Good luck!
Old Jul 11, 2002 | 02:57 PM
Incubus's Avatar
Can I take off my oem lip and put the amuse one on with the same mounting points?
Thanks.
Old Jul 11, 2002 | 07:34 PM
joe_s2k's Avatar
Thanks.
I'm not sure about the mounting points for the OEM lip, but both the Amuse & the Mingster IDI Front Lip require no modifications for installation.
You should have no problems removing the OEM and installing this one. Go for it!
This is the Import Development IDi Front Lip. PM Schatten or Mingster for details.
Old Jul 11, 2002 | 08:33 PM
seung's Avatar
amuse/ idi front rule!!!
see my sig...
Old Jul 12, 2002 | 07:58 AM
Shinji's Avatar
[QUOTE]Originally posted by joe_s2k
[B]
Mattmeister
Sep 7, 2005 02:15 AM
SilverKnight
Jan 21, 2005 08:24 AM
JspecVtec
Sep 2, 2004 10:33 AM
RotoRooter
Jan 27, 2004 02:32 PM
amongmany
Jul 7, 2003 05:20 AM
