Installed Berk TP and K&N intake
Old Sep 24, 2006 | 06:15 PM
KnowledgeIsPower's Avatar
Default Installed Berk TP and K&N intake
recently purchased Berk TP and K&N intake and today i got finally had time to put them on.
Thoughts on the intake: pretty easy install, only problem was my strut bar wanted to get in the way.....with the help of a friend we managed to man handle it into submission after a few attempts. once on and car started the unit hums, im not sure if this is due to the fact that i got it from another member and it needs to be cleaned already or that this is what the K&N do (if anyone can chime in and let me know i would appreciate it). fit and finish are good worth the money IMO.
Thoughts on TP: Install easy again, although i didnt have ideal setup to be under car. (spring bolts are a PITA).
after install of both i turned car on and let it run for a bit. . .car deffinatly smelled a little without the cat, but i can live with it.The intake hums so it sounds a little different. First drive i noticed a better kick once in vtec, and a little beefier sound-though nothing drastic.
overal im pretty happy with everything, i only spend 275 on both pieces shipped.
deff rec anyone who wants to do it to go for it.
Old Sep 25, 2006 | 06:27 AM
vtec9's Avatar
intake hum is normal. your stock intake also hummed (if you ever took off the airbox lid, you can hear it) but to a lesser extend because the intake box was designed to minimize noise.
Old Sep 25, 2006 | 06:35 AM
patastinky's Avatar
Was the test pipe fitted to your stock exhaust?
Sly Stamps and the Family Stone
Jan 15, 2006 11:14 AM
Tyler N
Jul 7, 2005 04:34 PM
tuney
Jan 28, 2003 12:24 AM
