Installed a stealth intigrated garage door opener
So my Audis both have the built in Home Link garage door openers, and I forgot how much it sucks not having that feature in a car. And there are several good reasons to have a homelink type of integrated opener:
-Garage door opener clutters up the interior / sun visor.
-In a convertable, you don't want your opener in the open; someone can swipe it, figure out your address from your tag or registration, and now they have a way to get in your house!
So I figured out a great way to integrate a garage door opener in the S2000, I took my regular garage door opener, and hot wired the circuit board so that two wires will complete the circiut for the button, then I can just wire that to a remote button under the steering column.
I popped off the A pillar, and there is plenty of room to mount the garage door opener at the forward base of the A pillar.
I then just ran the wires down under the dash, and mounted a stealth button at the bottom of the steering column. The range on the garage door opener is still great, and with the button under the steering column, no one will ever see it.
I took lots of pics, but I guess you can't upload pics to S2ki without buying a membership, so I guess I can't share those with you guys.
I too clip mine to the panel above my right leg. I included a strip of velcro on the panel and remote to keep it from sliding around (a problem when it's only clipped it to the panel). It works from about 100 feet away which is fine for me.
