Installing Bilstein PSS9 - help please
Old Sep 17, 2006 | 02:01 PM
r2d2's Avatar
Default Installing Bilstein PSS9 - help please
I am installing PSS9 now - without special tools I was able to take out rear shocks (I had lower Eibachs on them). Now I do not seem to be able to put PSS9 shocks in. They are too tall and I do not seem to be able to compress them. Any insides from whomever installed them already? Thanks!
Old Sep 17, 2006 | 02:09 PM
thetz99's Avatar
I used a 6ft 4x4 wood post to lever the arm down.
Old Sep 17, 2006 | 02:12 PM
Stratocaster's Avatar
So how did you remove the springs from the OEM shock to remove the OEM top hats?
It has been a while since I installed mine, but I do remember it being a PIA to lower mount into place. I think we used a pry-bar to do it.
Old Sep 17, 2006 | 02:19 PM
r2d2's Avatar
OEM shocks were not a problem since I had them already lowered with Eibach springs. To remove them with OEM springs I had to use a compressing tool. But that's not the case now. I have both rear shocks removed and can't get PSS9 on. I do not seem to be able to compress them somehow.
Old Sep 17, 2006 | 03:30 PM
r2d2's Avatar
okay, not one but a combination of two prey bars may seem to work. Hell the installation of Motons on my Viper was a breeze compared to this. Problem solved.
Old Sep 17, 2006 | 03:53 PM
Joel S2k's Avatar
u shud be able to fit them in...its either u get a buddy of urs whos heavy set and step on the hub to bring it down or use pry bar to to fit them in. Its a bit of a hassle if ur doing this by urself. I did mine without any issue. Unless pss9 has changed from the last time i had mine
Old Sep 17, 2006 | 03:55 PM
negcamber's Avatar
If you need to do this again sometime...this method works like a charm:
https://www.s2ki.com/forums/index.php?showtopic=338897
Old Sep 17, 2006 | 05:12 PM
MTP04's Avatar
^^^^Thanks for the link, great idea for a one man install.
Old Sep 17, 2006 | 06:38 PM
Steve@Evolution's Avatar
You can also unbolt the rear sways from the control arm, then it would very easy to have more room by stepping on the rotor. Have a buddy come over to step on it for you.
Steve - Evolution
703-961-9090
hex90
Nov 15, 2020 07:28 AM
stockae92
Sep 10, 2009 08:49 PM
mlc
Nov 16, 2007 02:56 PM
Danny_Spain
Sep 17, 2005 08:36 AM
Trip
Jul 25, 2005 01:22 PM
