installing oem lip
Old Apr 24, 2003 | 10:35 AM
EVAN_In_A_SPA's Avatar
I installed mine a few weeks ago. I feel the same, they say to use a push pin to make a small hole. What the hell kind of pin will pucture the fender!! It was all good though..
Old Apr 24, 2003 | 10:49 AM
Ganthet's Avatar
I installed the front and rear spoilers last week. The front required no cutting or drilling of any kind. I simply drove the self-tapping screws into the plastic bumper by hand with a screwdriver. You should have no trouble at all.
I had problems lining the rear spoiler up, but thats a different story. The front is a cakewalk though Good luck!
ninegrand's Avatar
Getting the clip nuts on the bottom were a PITA for me till I lossened the remaining 10mm bolts near the spot you are trying to insert them(4). Once you loosen these a tad the OEM black plastic "pan" will give you some play inbetween the pan and bottom of the bumper. then the clip nuts will slide in easily. Leave all the 10mm bolts slightly loose till the sides are on correctly, then snug everything up.
The self tapping screws become easier to install if you turn your wheels to allow more leverage and a straighter shot at the screws.
I remember reading a few weeks back where someone installed his in 10 min. Hmmm I guess I'm just not that good.
Take your time and you will love the lip once it's on.
Old Apr 24, 2003 | 10:50 AM
kush only's Avatar
[QUOTE]Originally posted by Umrswimr
[B]
The ones in picture 3 or the ones in picture 6?
Old Apr 24, 2003 | 11:11 AM
ninegrand's Avatar
Plz don't cut your car. Read my above post and simply loosen the bolts near the cutouts you are speaking of and they will slide in.
Old Apr 24, 2003 | 07:15 PM
kush only's Avatar
last questionh......can i remove my bumper....put on the lip...then install the bumper....or do i have to have the bumper on first then the lip.....
Old Apr 24, 2003 | 07:48 PM
SoDakS2K's Avatar
I suppose you could take the bumper off and then install the lip. It might be a little tricky to tighten some of the bolts, but you should be fine.
Old Apr 25, 2003 | 01:04 AM
Jason B's Avatar
OEM lip rules:
Janosh
Mar 23, 2014 10:43 PM
s2000tim
Mar 17, 2009 04:31 PM
Spoon Fed
May 21, 2008 07:06 PM
fisting dwarves
Oct 10, 2004 01:32 PM
Tedow
Apr 14, 2004 06:29 PM
