installing oem lip
Old Apr 24, 2003 | 06:34 AM
kush only's Avatar
Default installing oem lip
http://www.handa-accessories.com/S2000/s2kfuspoil.pdf
1. Does anyone know if i have to cut the two cutouts on the very left and right of picture #3?
2. do i fit the lip inbetween the clip nut or directly under it?
Old Apr 24, 2003 | 06:42 AM
SoDakS2K's Avatar
I had this problem to. I think it should fit from underneath the hole, but I put mine in from the top. You do not need to cut anyhting. I thought it was supposed to rest on the plastic piece of the bumper as well, but it does not. You have to feed it through the hole.
Old Apr 24, 2003 | 06:44 AM
kush only's Avatar
thanks for the reply....anymore help?
Old Apr 24, 2003 | 06:46 AM
SoDakS2K's Avatar
Use something a littlew stronger than a push pin to make a hole on the side. Self tapping-screw my ass! I had to put my whole body into it to get that thing to seat.
Old Apr 24, 2003 | 06:49 AM
KaliTurbo's Avatar
If you dont have alot of time nor expertise with modding cars, I believe Honda dealerships are installing the oem lip for like 30 bucks.
Old Apr 24, 2003 | 07:13 AM
Bass's Avatar
i just used my cordless drill and screwed the screws in on the sides - no problem -
the clips were a PIA but once you place then correctly into the slots it's easy - place the clips inside the holes and then fit - do not try to clip on the little lip where the hole ends (if that makes sence
took me a few tries
Old Apr 24, 2003 | 09:38 AM
Umrswimr's Avatar
I installed one on my old roommate's car in less than an hour. It's not real intuitive (as you're finding out), but not bad. The self-tapping screws were a bit of a PITA. Once you get under there I think you'll realize how it all goes together.
The clip-nut goes above the spoiler- the spoiler does not go between the clip nut. Sandwich the little bit of "cutout" between the clip nut and bolt the spoiler below. That will squish the clip-nut onto the bumper and lock your spoiler into place.
Old Apr 24, 2003 | 10:00 AM
kush only's Avatar
[QUOTE]Originally posted by Umrswimr
[B]I installed one on my old roommate's car in less than an hour.
Old Apr 24, 2003 | 10:23 AM
Umrswimr's Avatar
Originally posted by DavidKang
woah...thanks...you helped alot....but what about the outer cutouts.....they dont fit...should i cut them?
The ones in picture 3 or the ones in picture 6? I believe his fit in both cut-outs (referring to image 3). The ones in image 6 took a little finessing to get to fit right.
Old Apr 24, 2003 | 10:34 AM
Carlson's Avatar
