intake and exhuast comb.
Old Nov 21, 2005 | 02:51 PM
559s2k's Avatar
Default intake and exhuast comb.
well i found a combo:
1. AEM V1 intake
2. Skunk2 exhuast
i was wondering if the two would work for power...?
any thoughts?
Old Nov 21, 2005 | 02:53 PM
afwfjustin's Avatar
You're looking at 5 horsepower maximum.
Old Nov 21, 2005 | 02:54 PM
559s2k's Avatar
would that make any diff in the 1/4 mile?
Old Nov 21, 2005 | 03:06 PM
afwfjustin's Avatar
lol, no, 5 hp wouldn't make any difference.
If you're looking to drag, spend the money on a Comptech reinforced differential and a new clutch kit that has a stronger pressure plate. This is all you'll need to turn out some high 13 sec. passes.
Old Nov 21, 2005 | 03:20 PM
559s2k's Avatar
so then screw the bolt ons?
Old Nov 21, 2005 | 04:50 PM
gosixers215's Avatar
If your looking for power gains/more quickness, go another route. Bolt-ons like an exhaust and intake are good for more aggressive sounds, not much else it seems.
Old Nov 21, 2005 | 05:01 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Get a S/C"!!!
Old Nov 21, 2005 | 05:06 PM
559s2k's Avatar
i don't wanna be that fast...lol..
just enough for the streets...
in fresno, cal a low 14/mid 13 is fast enough.
Old Nov 21, 2005 | 05:08 PM
afwfjustin's Avatar
If you want bolt ons that provide gains for better driving around town, there are plenty. But adding intake and another dual exhaust isn't going to net you anything. The three biggest for the least amount of money are T1R 70mm single exhaust, rick's header, and VAFC+tuning. This will net you over 20 hp at the wheels for just under 2000 dollars. You could get the same effect from adding 4.56 gears for 1100 dollars. Or you could just spend 3 thousand on a used vortech supercharger and install it yourself.
Then again, if you want to drag, you need to fix the 'weak' points that make people say this isn't a drag car: the clutch and the rear dif.
Old Nov 21, 2005 | 05:10 PM
AJ PwR's Avatar
T1R exhaust has poven gains so you might want to look into that
