Jacking up by the differential?
Old Mar 19, 2003 | 05:53 AM
staffordaz's Avatar
Turns out one of my new rear tires was missing 10-15 psi. This is the second rear tire in three days to loose pressure. The other one was due to a bad/new valve stem.
I was noticing the body twist/torque in all gears whenever I tipped the throttle.
I pumped the tire back up and all is well (until it loses more air before I get it repaired).
When the other tire went low, I immediately knew what it was. But after having it happen once, I thought, "Nah, can't be another flattening tire...must be something wrong with my baby."
All is fine now. Thanx for the input.
Old Mar 19, 2003 | 07:26 AM
xviper's Avatar
Glad you figured it out and that it was a simple solution. "Body twist/torque" is a bit misleading a description. Steering to one side or the other with application and removal of throttle would have been more direct.
Old Mar 19, 2003 | 06:28 PM
Wesmaster's Avatar
What did I win?
Old Mar 19, 2003 | 07:34 PM
xviper's Avatar
Originally posted by Wesmaster
What did I win?
Would you believe .................................................. .................................................. ................
A bulletproof rear end?
Old Mar 19, 2003 | 08:17 PM
Wesmaster's Avatar
Henwhee
Apr 13, 2012 05:31 PM
RoninS2k
Mar 25, 2012 11:04 PM
TicketMagnet05
Dec 7, 2009 02:14 PM
clawhammer
May 24, 2006 11:12 PM
