J's 60 rs single
Old Nov 18, 2007 | 01:18 PM
CKR_soloRacer's Avatar
Default J's 60 rs single
Anybody have a pic of the clearance between the resonator and the lower brace under it? I cant seem to get enough of a gap to keep it from rubbing and making noise.
Old Nov 19, 2007 | 11:32 AM
leftyz's Avatar
mine has about 1/4 inch of clearance. dont have pics though.
Old Nov 19, 2007 | 06:42 PM
Did you use the stock rubber hangers? I might have to find some shorter ones.
Old Nov 19, 2007 | 07:01 PM
Bryan@BerkTechnology.com's Avatar
Former Sponsor
On our old AP2 we had to do two things to get the J's 60 to fit properly.
1. Make some spacers for the underbrace.
2. On the hanger on the B-pipe, we used a hose clamp to cinch down on the hanger, making it shorter & stiffer. Couldn't use a hanger that was too short because the B-pipe would have started to hit the body of the car. So the hose clamp trick effectively give us a "medium" length hanger.
On the AP1 you should have enough space under there to use a shorter hanger... if you can find one.
Old Nov 19, 2007 | 07:04 PM
I have already shimmed the underbrace with 2 washers, I'll try the hoseclamp on the hanger, thanks.
Old Nov 20, 2007 | 09:25 PM
GT Motoring's Avatar
Former Sponsor
is it a FX series exhaust? or old one? Ive had 2 different 70RRs as well as a 60RS on my AP2. No issues with either hitting anywhere. I used a more stiff hanger only at the very rear to replace the normal oem hanger
Old Nov 21, 2007 | 03:55 AM
Ike 2.2's Avatar
I had to use a shorter hanger and place washers between the frame and underbrace to keep my 70RS from hitting the underbrace or underbody. The exhaust is also really close to the drive shaft and has a small ding in it from being hit by it before I got the hanger/spacer stuff worked out.
aznsupastar
44
Apr 24, 2014 09:47 AM
m1sterlaw
Dec 13, 2008 08:41 PM
BSeriouS
Dec 30, 2007 08:25 AM
CKR_soloRacer
Nov 20, 2007 02:17 AM
kelvin96gsr
Jul 15, 2006 12:14 PM
