jdm headlight installation question
Old Mar 29, 2003 | 10:45 AM
kush only's Avatar
Default jdm headlight installation question
is it normal to startch up the fram when installing headlights? or is there a methodto squeeze it in without scratching anything...
Old Mar 29, 2003 | 06:34 PM
Red Blur's Avatar
Can you be a little more specific with your question? Are you clearing your headlights?
Old Mar 29, 2003 | 11:34 PM
coles2k's Avatar
When I removed and re-installed my OEM headlights, I was able to do it without scratching the frame at all by putting the outside corner in first with the light almost perpendicular to the front of the car, then moving the inside corner of the light into position as the light moves into place.
Hope this helps to answer your question.
Old Mar 29, 2003 | 11:46 PM
Station's Avatar
Allow me to translate:
"Is it normal to scratch up the frame when installing headlights, or is there a method to squeeze it in without scratching anything?"
Old Mar 30, 2003 | 12:50 AM
Red Blur's Avatar
Thank you...I was a bit confused there for a sec. As Coles mentioned above, you should be able to slide them in fairly easily without them being scratched up (or startched up ) at all. Good luck.
Ro_Ja Boy
May 21, 2009 10:53 AM
jvr
May 6, 2009 06:57 PM
camera obscura
Feb 28, 2006 06:21 PM
jiggagnome
May 23, 2005 11:26 AM
KenGPW
Jan 4, 2004 09:24 AM
