Js2k LED light issues
Old Jun 10, 2011 | 04:03 PM
OldDog's Avatar
To Joey.
Old Jun 10, 2011 | 04:26 PM
spurfan15's Avatar
Originally Posted by jyeh74
Hi guys, I tried playing with the metal wires but no matter what, the lights didn't work. Its weird because I've had them for about 2-3 weeks with no problem. They just went out. Its not a socket issue I dont think, because the stock bulbs work fine. Joey, like I said, maybe I got a bad batch? Thanks for making it right.
Sometimes it's due to seating issues, but sometimes LEDs will burn out. I have a voltage supply in the lab where I work and I've tested my LEDs using the supply. A few of my white parking light LEDs burned out as well after a similar time period. LEDs last for a long time when they're manufactured right, but if there are problems with the LED chips, the resistors, the extra diode they include in the package, or if the current / voltage exceeds the rating, then they can fail.
In this case, it may be some defects from the manufacturer. What's important is that Joey treats his customers well and will get replacements to you if your lights fail.
Old Jun 16, 2011 | 06:41 PM
jyeh74's Avatar
How long do LEDs last usually? How do I know its not the parking light wires?
Old Jun 20, 2011 | 05:07 PM
jyeh74's Avatar
Joey being the great guy he is, sent me replacement bulbs for the parking lights. But after 8 days, they went out again. I think it might be the wires being incapabitible with the LED bulbs? I just put my stock bulbs back on...ugly I know, but these LEDS keep going out. Thats the second pair in a month or so! Please tell me other folks have this issue with parking lights.
Old Jun 20, 2011 | 07:26 PM
TheMuffinMan's Avatar
I'm just going to toss it out there that I find it really unlikely for both sets of LED bulbs to be damaged or bad when so many other users have them just fine. I'm going to wager the issue probably lies in your vehicle (voltage spikes, bad wiring, etc) You may want to see if those bulbs will work in another S2000 before blaming the LEDs.....
Old Jun 20, 2011 | 09:01 PM
JS2k.com's Avatar
Sponsor
Sorry, I've just returned from a family emergency. Jason, I'll be responding to your emails tomorrow morning.
But I really don't think there should be any reason the LEDs should be going out like that. Especially so many in a row. I'll definitely get you taken care of.
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
Old Jun 20, 2011 | 10:53 PM
ahrmike's Avatar
OP, before a new set, clean out the contacts on your lights with some fine grit sandpaper. Then, make sure the contacts are still "springy" If the contacts are too loose or are slightly corroded, the resulting resistance could be killing the LEDs.
IMO, LEDs do have a less-hardy nature. EVERY LED light I've purchased, dive/mag/whatever has died before my xenon light. LEDs are supposed to have "longer life" but just like CFLs, I think the complexity of the product causes it to be less reliable.
BTW, JS2k, thats great customer service
Old Jun 20, 2011 | 11:58 PM
xedk's Avatar
+1 on the customer service
i had one led with contact issues and he sent me another one right away after i emailed him.
now they all work fine and look great!
Old Jun 21, 2011 | 02:50 AM
termigni's Avatar
i believe it's not only Js2K's LED bulbs. I used to have LED parking light and samething happened to me. kept going out. Now i'm back on normal light bulb.
it is not JS2K's fault at all. I think it must be the amount of current going into that socket that is causing the outage.
Old Jun 21, 2011 | 11:40 AM
01S2KSA's Avatar
Can't blame Joey...he's a great guy with the best customer service. I had my license plate light go out too and got a replacement sent out the day I emailed him. Haven't had a problem ever since. It is something with the rear license plate light socket or wiring....if it goes out again, I will further investigate.
