Just bought 02' S2k need some info
Old Feb 22, 2005 | 06:12 PM
cramos502's Avatar
Default Just bought 02' S2k need some info
I just bought a 2002 s2000 with 7k miles only. I noticed the front tires is not the same size on rear i need some info. what is the right tire size for this car?
sorry for the post first time owner of s2k
any info will be appreciated
Old Feb 22, 2005 | 06:23 PM
Convict's Avatar
The rear tires are supposed to be bigger then the fronts because the car is rear wheel drive. The front should be either 205 or 225 width..
Old Feb 22, 2005 | 06:26 PM
joshthorsc's Avatar
Welcome to s2ki!!!
Try using search, you'll find lots of info there. The s2000 is a rear wheel drive car and built for performance. They have staggered wheels, so the fronts wheel/tires are skinnier than the rear wheel/tires. If your buying oem tires then it's 205/55/16 up front, and 225/50/16 at rear. However, if you don't buy oem tires, then the front tires size remain the same but the rear tires should be 245/45/16. If you use the search, you'll find more info that can explain the reasons better than I can.
Old Feb 22, 2005 | 06:34 PM
cramos502's Avatar
thanks guys for the info
ljsimp
Feb 3, 2010 05:55 AM
natefkb
Aug 3, 2008 11:27 AM
tongman
Mar 17, 2006 02:29 AM
cramos502
Feb 24, 2005 04:25 AM
vlopes
Apr 12, 2002 12:26 AM
