Wrong Tires?
Old Feb 2, 2010 | 08:16 AM
ljsimp's Avatar
Default Wrong Tires?
Hello everyone,
My name is Logan and I drive a 02 Honda S2000. I just purchased this car 2 months ago after many years of owning 2 Civic, Integra, and Prelude.
The car came with these tires, and I just realized the fronts looked bigger then the rear.
Front - 225/55/16
Rear - 225/50/16
These are the stock wheels BTW. The tread in the front are excellent, the rear are 50%. What should I do? I imagine the previous owner may have rotated them, can I tell which is the rear original wheel?
Any advice would be greatly appreciated.
Thanks
Old Feb 2, 2010 | 10:09 AM
1nate7's Avatar
The S2000 has 2 different hub sizes, the rear wheels (wider) should not be able to be mounted on the front. The rear wheels have a smaller hub bore and are 1" wider, if you take them off the car you should be able to tell. The front tire size should be 205/55.
Old Feb 2, 2010 | 11:51 AM
ljsimp's Avatar
So if I have 225's both in the front and rear your saying that 225's should have not been able to be installed on the front? I guess what I am aiming for is what would you all do in my situation?
Old Feb 2, 2010 | 01:17 PM
1nate7's Avatar
I am saying the rear WHEELS shouldn't be able to fit on the front. It sounds like they mounted 225/55 tires on the front wheels but you need to make certain.
I would move the 225/55 to the rear and the 225/50 to the front but you can't simply rotate as I already mentioned, you need to have them dismounted and remounted. That is the cheapest solution, the other is to buy proper sizes.
Old Feb 3, 2010 | 05:55 AM
ljsimp's Avatar
Ok sounds good, I appreciate your clear response I understand 100% now.
JLUDE
Sep 8, 2009 11:13 AM
bluemeanie
Jul 14, 2007 10:53 AM
s2kride
Nov 30, 2006 01:00 PM
tlegend
May 18, 2006 10:19 AM
vlopes
Apr 12, 2002 12:26 AM
