just bought a my02!
Will put pictures up soon
I'm happy to be part of the family. It's a yellow 02 with 40k ish miles on it. Some things that i've noticed in the couple days i've had it and i wanted to run this by some experienced owners:
i get a clunk sometimes between 1-2 and 2-3 ... happens usually at low speed and lowish rpm maybe around 3 or 4k. It's not a grind perse but kind of a heavy sound when i shift. It happens maybe 2 or 3 percent of shifts between these gears.
When i drive over imperfections (not pot holes but like considerable bumps) the suspension makes the same sound that any other normal car makes when the shocks aren't working so well. I figured this was due to how tight the suspension is because the car doesn't bounce around as if the shocks aren't working and the my07 that i drove brand new made similar noises - just wanted to confirm.
There are some rattles when driving with the top up ... i figure in such a stiff car there may be some - i can't localize them but they are faint and there - any ideas?
The previous owner changed engine oil ever 5k with either amsoil or mobil 1 and changed tranny/diff fluid ever 15k. Should i keep up this routine? I'm used to changing my synthetic motor oil every 5k but not the other two (i used to own volkswagens/audis).
thanks for the input guys and i really look forward to being in this community
I'm happy to be part of the family. It's a yellow 02 with 40k ish miles on it. Some things that i've noticed in the couple days i've had it and i wanted to run this by some experienced owners:i get a clunk sometimes between 1-2 and 2-3 ... happens usually at low speed and lowish rpm maybe around 3 or 4k. It's not a grind perse but kind of a heavy sound when i shift. It happens maybe 2 or 3 percent of shifts between these gears.
Originally Posted by slipper,Dec 16 2007, 08:37 PM
Get a new strut and spring combo and buy my rims......
As for the spindle nuts, just spoke to the dealer and since the car is still under powertrain warranty he'll have a look and see if that's the problem - i noticed it a lot less today once the car had warmed up.
