Just got a letter from Honda.
My 2000 S-Type is up for its 30,000 mile scheduled Maintenance!
Then want to Replace the timing belt(its a chain), Inspect the water pump, Replace all accessory drive belts and replace the coolant.
Up above it says......"Honda recommends timing belts every 90K Miles/6years, Not 60K Miles(varies by model)."
What a load of garbage!
This sounds very much like the typical Honda service notifications sent out for any Honda. Since virtually all others use timing belts (not chains) and they are supposed to be changed every 90k miles, I suspect that it's not customized for the S2K. Call the dealer to verify but there's no reason short of a recall/TSB for changing the chain at this low mileage. Chains last MUCH longer than belts...
Its from my local dealer! I think I should bring this up to the dealer and tell them to shove their timing belt. Though they seem to send this thing just after I pass 30,000 miles!!!
Hell what if I only had 3,000 miles on the car! Does or ODBII send out our milage to Honda?!
