Key Mechanism problem
Old Apr 27, 2008 | 01:36 AM
fastfatdude's Avatar
Default Key Mechanism problem
hi all,
my car is 2 months old but i seem to have a problem with the keyhole mechanism.
when u turn off the car and before taking out the key, there will be a non-stop beep-beep sound, the sound is supposed to go off when u extract the key.
my problem is that when i take out the key, the beep-beep continues and when i close the door after getting out, the car wont lock.
i think there is some internal sensor/flap in the keyhole mechanism that senses the key is out thereby switching off the beep and thus allowing the car to be locked.
i cant send the car into the dealership as this is an intermittent problem. I get this like 30% of the time when i turn the car off.
anyone has this same problem? and is there a way to solve it permanently?
thanks
ffd
Old Apr 27, 2008 | 02:07 AM
ian05s2k's Avatar
I had something similar happen once like the first or second week I had the car, but i just turned the key back to the first position and then back and it went away and hasn't done it ever again. I would defiantly be pissed if it happened a lot though. Have you tried taking it to the dealer? They may have run into someone else with a similar problem. Worth a try at least. Good luck man.
-Ian
Old Apr 27, 2008 | 07:54 PM
will just drive a bit more to see how it goes.
if the problem persists, i will complain to the dealer when i send it in for 10k servicing....
Old Apr 27, 2008 | 10:56 PM
Series10's Avatar
mine did that too, you have to tap the key around the keyhole until you hear the click. Sucks, I know.
Old Apr 28, 2008 | 02:50 AM
berlino's Avatar
Mine does the same thing. Thinking about going in to the dealer with the problem.
Old Apr 28, 2008 | 08:33 AM
today, stopped the engine 3 times.. problem didnt come back... darn.. i hate intermittent problems...
Old Apr 28, 2008 | 08:41 AM
///MIKE's Avatar
Mine has the same thing. If you take your finger and tap it you'll here it click and it will go away...It's really annoying thats for sure.
Old Apr 28, 2008 | 09:29 AM
shamoo's Avatar
Very common problem. Happened to my brand new 2007 right when I took it home from the dealer. Check out the "Ask Honda" forum and you'll see many many members with this issue.
When you turn off the car, the mechanism doesn't fully "click" so it still thinks the key is in the ignition. That's why the beeping is stilll there (the door is open with the key in), and that's why you can't lock it (can't lock/unlock doors with key in).
Old Apr 28, 2008 | 09:31 AM
BerlinaBlackS2kguy's Avatar
the thread shamoo is referring to: My car thinks the key is still in ignition (s2ki.com)
my car has done it a few times, usually when it's hot out i've noticed.
Old Apr 28, 2008 | 04:37 PM
thanks for the thread headsup...
tsukubaSpec
May 31, 2016 05:28 PM
zenairdave
Feb 16, 2012 06:30 AM
Jersey
Sep 1, 2008 12:53 PM
DonTTgo
Nov 12, 2004 01:38 PM
fitness3
Jun 10, 2003 06:29 AM
