KONI with Ground Controls
Those of you running Koni yellows with ground controls, did you have to cut the front bump stops, I am trying to put mine back together after taking the stock shocks out, and I cant get the top hat to fit, looks like the bumpstop is too big. Let me know.
Ok looks like im going to have to cut the bumpstop, under the load, it only looks like i will get one to two inches of suspension travel.
Also how the hell do you turn the collar up, i need to lower the car about .75 of an inch, but i can move the collar, its under load? Any special tool needed. Also, the sleeve itself spins on the Koni, is this normal, I would think the sleeve would need to be stationary? HELP!
