Sponsored by: CARiD
Koni with Swift Sping
Old Dec 8, 2008 | 12:14 AM
albe's Avatar
Default Koni with Swift Sping
I was wondering how long does the koni with swift take to settle down? i have have it on the first perch and the car look that same.
Old Dec 8, 2008 | 02:44 AM
hk_s2k's Avatar
i believe the first perch is the same height as the stock strut, try the lower perch.
Old Dec 8, 2008 | 08:32 AM
albe's Avatar
thanks hk
Old Dec 8, 2008 | 08:39 AM
albe's Avatar
how do set it to the second perch? also my settle down a little bit but not for my driver rear still has 4-5 finger gap and the side has 3 finger gap.
Old Dec 8, 2008 | 12:41 PM
littlerocket777's Avatar
You have to pry off that yellow ring on the shock and move the ring down to the next recess.
Old Dec 8, 2008 | 05:39 PM
wisdom's Avatar
I think the lower perch lowers about 20mm.
Old Dec 8, 2008 | 11:06 PM
albe's Avatar
anyone know why my driver rear side gap is bigger than the left side?
Old Dec 9, 2008 | 08:28 AM
frei's Avatar
did you preload the suspension?
Old Dec 9, 2008 | 12:11 PM
albe's Avatar
what is preload the suspension? well i put in the shock and just bolt them right up
Old Dec 10, 2008 | 09:14 AM
harrrrry's Avatar
I have this setup on the lower perch. I had it on the high perch at first and you'll only notice the drop difference next to a stock ride height one. If not, it looks un-lowered. I have mines on the lower perch now and looks much better.
I don't know how long it takes to settle but if it does at all, it won't really settle much more like other springs like Teins.
To lower the ring, you can do it easily with a circlip plier, or any tool you can find to open the ring so you can move it down. All you really need to do it open it enough out of it's place then slide it up or down
thielepr
Nov 5, 2014 02:34 PM
JoeyBalls
17
Mar 25, 2009 10:24 AM
freds20002002
Feb 7, 2009 12:39 PM
s2kotty
Jan 9, 2009 10:04 AM
Blue2002
Jul 6, 2003 12:39 AM
