which koni shocks does everyone use
Old Nov 30, 2003 | 01:33 PM
s2kbtheway's Avatar
Default which koni shocks does everyone use
Which koni shocks are used for the s2000. I have kgmm race springs and dont know which shocks to buy. pics and thoughts would be nice
Old Nov 30, 2003 | 02:30 PM
RazorV3's Avatar
koni yellows are the way to go, i dont even know if they offer koni reds for the s2000. but if they do, don't get the reds.
Old Nov 30, 2003 | 03:46 PM
Portland's Avatar
I use the koni yellows with my kg/mm race springs.
Old Nov 30, 2003 | 05:18 PM
s2kbtheway's Avatar
im going to go with the koni yellows . i have done some research and found that it it the best way to go
Old Nov 30, 2003 | 05:34 PM
VelozS2K's Avatar
I have some Koni Yellows for sale if you're interested. They're brand new in the box. I got them from another member on this board but I've decided to hold off. I'll post them on the for sale section in a few days. Thanks.
Old Nov 30, 2003 | 05:38 PM
turbo_pwr's Avatar
I'm pretty sure Koni only makes one off the shelf application for the s2000
Old Nov 30, 2003 | 05:43 PM
RazorV3's Avatar
honestly koni yellows ARE the best afternarket shocks/struts you can buy. they are height and frimness adjustable too.
Old Nov 30, 2003 | 05:48 PM
s2kbtheway's Avatar
as far as the height adjustment. how does one adjut the height
Old Nov 30, 2003 | 05:54 PM
RazorV3's Avatar
the body of the shock has different perch settings and there is a ring. you move the ring to any of the perch settings and that will adjust the height(this is where the spring will rest on). in other words, once you install the shock with the chosen perch setting, you cannot change it. you need to make sure you choose the right perch setting before installation.
as far as the firmness adjustment goes, that can be adjusted at any time. there are these white knobs that koni supplies and you attach it to the top of the shock body. for the front adjustment, you need access through the engine bay. for the rear adjustment, i *think* you will need to pull back the carpet lining in the trunk to get to the top of the shock(well atleast thats how it is on my 94 accord).
Old Nov 30, 2003 | 10:31 PM
BryanH's Avatar
Is that adjustable spring perch SCCA B-Stock legal? I have Koni Yellows in my MR2 but they are just strut inserts - you can't adjust ride height with them.
