larger wheels and speedo question
Old Dec 28, 2003 | 07:48 PM
wanabe's Avatar
if i go to 18" wheels i understand that i should lower the car cause it sits a bit higher...
if this is the case, wouldnt the overall wheel circumference be larger?
(am planning ssr gt-3s with eibachs)
and if so, does the speedometer/ odometer need to be adjusted for the change?
Old Dec 28, 2003 | 08:04 PM
ttb's Avatar
ttb
you dont need to lower the car. if you get 18s you should be doing a plus 2, so the wheel size increase, but the tire's profile is less, so the overall diameter should be roughly the same. some people think lowering it makes it look better, but you dont need to lower it.
Old Dec 28, 2003 | 09:53 PM
WRS2K's Avatar
your car isn't sitting any higher than a stock s2000.
it just looks that way because your eyes are playing trix on you. the gap between tire and fender looks a lot bigger with your 18s because you now have more shiny SSR metal v. 16" tire black sidewall.
lower away. it'll look a LOT better.
Old Dec 29, 2003 | 07:52 AM
wanabe's Avatar
great advice-
thx guys...
will lower it with eibachs.
might lower it with the stockers until i get the 18s-
Old Dec 29, 2003 | 09:37 AM
Black Nugget's Avatar
it is said that larger wheels have the ability to cause your speedometer to read a little bit off, however it is nothing major. if your seriously worried about it, i would go ahead and get it done. but i had 18" wheels on a honda civic before.. never really had a problem.]
chad
Old Dec 29, 2003 | 10:12 AM
Scot's Avatar
like others said, you just make sure you get the right profile (255/35/18 vs 225/50/16) which will compesate for the larger wheel
the total heighth of the tire
= 16" wheels x 25.4 mm per inch = 406.4 mm
+ 225 x 50% (profile) = 112.5mm x 2 (which is for the top part of the tire plus the bottom) = 225.
Grand total = 631.4 mm
= 18" wheels x 25.4= 457.2 mm
+ 255 x 35% (profile) = 89.25mm x 2 = 178.50
Grand total = 635.70 which is only 4.3mm (1/6th of an inch) taller.
beefcake191176
May 10, 2005 04:05 PM
jdnissanz
Feb 26, 2005 04:46 PM
Tony Yeung
Oct 19, 2004 02:17 PM
gheyland
Jun 27, 2003 05:09 AM
Primer
May 28, 2001 01:09 AM
