LED domelight
Old Apr 5, 2010 | 08:29 PM
boosted180sx's Avatar
Default LED domelight
First off, sorry if this is not in the right section.
I just put on my Led domelight today and for some reason, the domelight is still lit when i put it onto door mode (the middle). If I move it to off (the very left), it turns off.
It's very dim but still noticable that it is lit up. What would be some possibilities for it to act like this?
Old Apr 5, 2010 | 10:41 PM
omairtheman1's Avatar
LED's usually require a resistor because they consume less energy...
are you sure you got the right one specified for the car?
Old Apr 6, 2010 | 09:16 AM
I got these.
anybody else had a problem after putting these in? I understand how the LEDs don't require as much power to turn them on so when in "door mode" its still faintly on. but it's just pretty annoying, and was wondering if there was any way to fix it.
Old Apr 6, 2010 | 01:21 PM
mister x's Avatar
Try switching back to your original bulb and check it with the lens off, if it also faintly glows you may have a sticky door switch. I have the same LED in my MY04, no problems.
Old Apr 6, 2010 | 02:07 PM
hmm, alright will do when i get off of work.
How would you fix a sticky door switch?
Old Apr 6, 2010 | 07:13 PM
alright, so I guess it is because LEDs draw such low power that its lit up even when i have all the doors closed. When i replace one of them with a stock bulb, I think it creates enough resistance so it doesnt turn on.
noone else has problems? it's just very annoying to have it lit up for no reason
Old Apr 6, 2010 | 08:00 PM
ebchu's Avatar
i had this same problem, but when i connected my aftermarket alarm system it decreased the voltage enough to turn off the leds completely
Old Apr 7, 2010 | 04:31 AM
takeshi's Avatar
No problem here. I'm not using the exact same LED board light though so there could be a difference there.
Old Apr 7, 2010 | 06:12 PM
hmm well, that seems weird.
Well, I went to radio shack and put a resistor inline to it and that fixed the problem.
thanks for the replies tho guys!
BestaNesta99
Nov 4, 2011 01:16 AM
vti stu
Jan 12, 2010 01:19 PM
o'malley_808
May 25, 2008 06:11 PM
DrCloud
Mar 15, 2006 06:31 PM
Roadkill
Jul 8, 2004 06:06 AM
